Click Here
14" wheel question
Old Jan 10, 2013 | 03:35 PM
speedaddict78's Avatar
Certified Car Crazy
Question 14" wheel question
Will a 14x7 wheel with 3" backspace and 205/70 tire work up front on a 78 cutlass?
I currently have 15" wheel with 2"backspace and it hits the back side of the inner wheel well when cut hard left or right...
Old Jan 10, 2013 | 04:02 PM
It hits the lip or the flat spot area in the back? What is the wheel width on your 15's?
Old Jan 10, 2013 | 05:14 PM
Certified Car Crazy
Hits the flat spot area...
Not sure, i wanna say either 15x6 or 15x7 cragar ss wheels.
Old Jan 11, 2013 | 07:21 AM
Has your car been lowered? That size wheel should be fine, you might try a smaller diameter tire.
Old Jan 13, 2013 | 04:55 PM
Certified Car Crazy
Car has not bern lowered.. I have a good 2"+ between the top of the tire and the bottom of the fender lip.
I think it's just the backspacing, pushing the wheell too far out, changing the turning radius of the wheel.
Like i said, had no issues with the factory sslI wheels.
I found a set of the hurst 15" rallys i may pick up an try. If a 15" factory wheel hits, then something else is up..
Old Jan 13, 2013 | 04:56 PM
Certified Car Crazy
Current tire size is 215/60 15.,
hurst68olds
Mar 31, 2014 12:38 PM
MDchanic
Wheels and Tires
22
Aug 4, 2011 10:23 AM
Swed Olds
Nov 18, 2007 04:51 PM
Ryhelio
Jul 7, 2007 11:49 AM
