cylinder heads "J" or "H"
Old Nov 8, 2007 | 12:47 PM
Swed Olds's Avatar
Member
Question cylinder heads "J" or "H"
Hi there
Is there anyone out there who can help me with cylinder heads of the 1964 394”?
On my car the ID on the cylinder heads starts with an “H”. One of them is cracked so I get another one, there the letter is “J” in the beginning. Is there a big different between them, can use the “J” marked on my engine, can I use the same valves as in the “H” head?
Thanks Per
Old Nov 8, 2007 | 01:35 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
J and H heads are for a 455 olds motor.
Also the H head is VERY RARE and valuable. Are you sure it is an H head that you cracked?
I'll definitely take it if you don't want it anymore.
Is this car in Sweden?
an H head is probably worth twice the amount of the car that you have it in.
Old Nov 8, 2007 | 01:40 PM
and yes if it is a 455, the j heads will swap.
Old Nov 8, 2007 | 01:45 PM
88 coupe's Avatar
Junior Member
Originally Posted by Swed Olds
........ of the 1964 394”? ........
Norm
Old Nov 10, 2007 | 02:27 AM
Swed Olds's Avatar
Member
It must be some kind of mistake, i´m talking about a 394" from 60-64 and my head has the ID: "H 069 822L and the other has: J 281 677.
And the reason is that i saw on tha Falcon sales E-store, it was different valves for Starfire and the other ones (i have an Dynamic 88 but what car the "J" head came from I don´t have any idea.
//Per
Old Nov 18, 2007 | 07:04 AM
I'll be damned.......
Could someone further explain this to me?
Different heads all together?
Old Nov 18, 2007 | 04:51 PM
I see. Thanks.
I have never even seen a 394 before.
defiant1
Aug 22, 2015 08:13 PM
vanguardtdc
Mar 30, 2015 09:32 AM
coldfire
Jul 19, 2013 08:20 AM
67442nut
Brakes/Hydraulic Systems
Jun 16, 2011 06:14 AM
