Mechanical Furl Pump Help
Hello all. I have a 70 cutlass that had a 1969 455 installed by the prior owner. The fuel pump appears to be bad and I’m looking to replace it. However, there’s a fuel return line not hooked which I assume was hooked up on the original 350 engine(that too is an assumption)So I guess my question is does or did the 69 fuel pump have a return line to the tank? Would it affect the performance if I bought a 3 port pump and hook that back up? Not sure if it matters but it does have A/C. Thanks in advance for the help.
Check on the tank. If there are two lines/nipples on the tank, then you should get the pump with three ports. The larger of the two lines is fuel supply, the smaller is the drain-back/vapor line.
Gone Johnson
May 18th, 2020 07:22 PM
