Yearly maintenance
Old Sep 1, 2020 | 08:02 PM
davertr's Avatar
Yearly maintenance
I have a 1972 olds 442 with 455 automatic with quadra jet 4bbl carb. What is everyone's suggestion for yearly maintenance to keep it running great and keep it safe?
Old Sep 1, 2020 | 08:46 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
-Change All....ALL fluids. Pwr Steering, Coolant, Brake, Diff, Trans & Filter. Engine oil.
-Inspect hoses n belts. When was the last time the cooling system was flushed and t-stat replaced?
-Replace the fuel n air filter. Inspect PCV.
-Brake fluid should be bled every 3ish years depending on miles or static time and storage conditions. Consider replacing the 3 rubber brake hoses before bleeding the brakes.
-Clean, inspect, repack front wheel bearings.
-Clean then wax the hell out of the chrome.
-Treat the weather seals.
-Inspect then grease the chassis.
-Lube the door, hood, trunk hinges etc...
-Vacuum out the trunk especially the drop-offs.
-Inspect the tires. Older than 10? Replace!!!
This oughta keep ya busy.
455m20
Oct 13, 2015 10:00 AM
tru-blue 442
Apr 20, 2013 02:48 PM
Apr 19, 2013 05:41 AM
ent72olds
May 29, 2009 09:27 PM
BigBertha442
Mar 13, 2008 03:48 PM
