Please help - Decode 71 Olds Cutlass Cowl Tag
Old May 30, 2020 | 02:55 AM
sammi_maakaveli's Avatar
Hey there fellas,
I was hoping someone could help.
I’m looking to purchase a 1971 Oldsmobile Cutlass and wanted to decode the Cowl Tag.
details are:
ST 77-33687 R 17223 BDY
TR 947 75 A PNT
06D234
if someone could help decode it would be much appreciated.
Regards
Sam
Old May 30, 2020 | 03:16 AM
69CSHC's Avatar
Originally Posted by sammi_maakaveli
details are:
Hey Sam, welcome aboard.
The first 2 numbers after ST are 71, so it is indeed a 1971 model. The next three digits 336 indicate it was born a V8 Cutlass.
The rest I will have to dig for....
Old May 30, 2020 | 03:24 AM
Old May 30, 2020 | 03:27 AM
Thank you so much 🙏
Old May 30, 2020 | 03:43 AM
rob1960's Avatar
The "R" after the 33687 cutlass v8 code is for the Arlington, Texas assembly plant. 947 is a white bench seat interior, 75 is your paint code "matador red" the A is a white vinyl top. The 06D is the 4th week of June '71 when your car was built. Not sure what the "234" is after your build date
Old May 30, 2020 | 04:43 AM
thank you very much Rob🙏
Old May 30, 2020 | 04:52 AM
VC455's Avatar
Barely Registered
The 87 in the sequence 33687 indicates it is a Holiday Coupe (2 door without pillar between front and rear windows).
Old May 30, 2020 | 05:18 AM
Thank you for your help VC455
Old May 30, 2020 | 08:40 AM
rcorrigan5's Avatar
Randy C.
So let's put it all together so you know what it all means.
ST 71 = style/model year = 1971
33687: 3 = GM division = Oldsmobile; 36 = model series = Cutlass V8; 87 = body type = hardtop coupe
R = assembly plant = Arlington TX
17223 BDY = Fisher Body production number (this number has no relationship to your vehicle identification number)
TR 947 = interior color and front seat type = white interior with a bench seat
75 A PNT = lower and upper body "color" = matador red (75) with a white vinyl top (A)
06D = time build code = June (06), fourth week of that month (D), 1971
234 = ?
Randy C.
Old Jun 1, 2020 | 03:51 AM
Thank you guys for all the info! It is very much appreciated
cconnors
Apr 30, 2020 05:28 PM
83Delta88
Apr 8, 2020 03:55 AM
Mossy
Mar 11, 2020 06:11 AM
preacherinseville
Jul 8, 2012 03:05 PM
preacherinseville
Jul 8, 2012 02:36 PM
