Distributors
Old Sep 18, 2020 | 11:32 AM
JPinAZ's Avatar
Distributors
Are BBO and SBO distributors physically the same? Other than timing curves will they interchange?
Old Sep 18, 2020 | 11:41 AM
gs72's Avatar
72Cutlass S
Yep.
Old Sep 18, 2020 | 11:48 AM
JPinAZ's Avatar
Old Sep 18, 2020 | 04:34 PM
edzolz's Avatar
All of the Olds points type distributers interchange. The HEI with three wires works also. The five wire HEI works if wired correctly.
Old Sep 18, 2020 | 07:46 PM
Originally Posted by edzolz
All of the Olds SECOND GENERFATION points type distributers interchange. The HEI with three wires works also. The five wire HEI works if wired correctly.
I added some clarification to your post.
Old Sep 18, 2020 | 09:10 PM
edzolz's Avatar
Not needed, his question was about big block versus small block.
Old Sep 19, 2020 | 05:16 AM
To expand a little, all 1964-1990 Olds V8 distributors physically interchange. Some aftermarket intakes (mainly those built in the 1960s) won't clear the larger HEI body. And be aware of the 1980s CCC HEI distributors that do not have a vacuum advance can - these have no internal advance mechanism since the advance curve is provided by the ECU.
Old Sep 19, 2020 | 09:21 AM
Old air cleaners may need clearanced for HEI, as well.
Old Sep 19, 2020 | 09:41 AM
JPinAZ's Avatar
Thank you for all of the info. I was hopping to use the original 260 HEI distributor with a 455 swap. Air cleaner should also be reusable because it has a dual jet carb. One of the stranger things I have seen. I still need a 455 engine and intake.
Old Sep 19, 2020 | 01:06 PM
I've wanted one of those as a conversation piece.
drjr56
Apr 19, 2020 07:27 AM
nonhog
Feb 18, 2012 07:02 PM
Charlie_brown
Oct 11, 2010 02:11 PM
The Stickman
May 26, 2010 07:37 PM
lunatic
Jan 14, 2005 12:02 PM
