Convertible top switch rebuild
So now the the rallye gauge issues have been sorted out by redoing the temprature sensor connector and while at it I redid the alternator connector. My convertible top switch went bad last weekend which I amd know addressing. So here is my question. I had another switch which I took apart last night cleaned the contacts and housing, since it had been used. I did have to do a slight filing of the up and down contect pins. There was a slight black burn divot on both contact pins that the armature meets when switch is in the up or down position. After I re assembled the switch and checked the movement of the switch it does a slight click in the up and down position and the rocker returns back to center. Is this the correct function of the switch button? Also when I diss assembled the switch and removed the pin board the up and down pins were loose in the plastic and the pins fell out of the board. I place them back in the board and cemented them into place and cleand the contact points. During re assembly and re installing the board I noticed the plastic housing has furrels which holds the pin flange in place. The board after installed in the housing holds the pins in place, but the up and pins do have some play but are not falling out since they're held in place by the housing. Should I be concerned that there is a slight movement on these two pins? Or is that normal.
I would think slight movement may be normal. Have you tested it to see if it works? You can leave it uninstalled with the wires connected or test with an ohm meter. If it works you might as well give it a shot. New ones are about $100 and readily available. I had purchased a new one and where the wires went into the back they were not tight and it created a problem. When I got a replacement the wires were now epoxied in place and I had no issues.
Steve
Steve
Just wondering if the wires fell off the back like mine did. Unfortunately I waited to long to return it. When I ordered a new one it was a better quality that has held up. I think I ordered from Parts Place for about $95-100.
Steve
Steve
. The OEM Switches are generally higher quality, but these switches do see some current so the contacts do degrade over time. The pins need to be tight even if you need to use some epoxy for a repair. Good luck.Rick
Thanks Phoenix8990,
I haven't gotten under the dash yet but do not expect to find any loose wires. The toggle switch after the top motor stopped got really stiff indicating that to me the issue might be internal. But I'm waiting on an original switch that someone had listed on Ebay. Not the NOS one but a used original switch and harness out off a Vista Cruiser. Oh course I should probably also check out the Convertible top relay.
