Fuel Pump question: 69 400ci
Old May 14, 2020 | 08:05 AM
grannys442's Avatar
I'm new to Olds so apologizing in advance. Looking to replace fuel pump on '69 442. Has a 400 with AC. Couple questions:
1. Seeing 2 lines from tank to pump. Maybe unique to AC cars ?? Is one hose a return line to the tank...or what's purpose of second line ?
2. Is there a preferred source/brand/vendor for a 2-line pump. Appears some vendors don't list pumps for AC equipped '69 400 config.
Thanks,
Adrian J.
Old May 14, 2020 | 08:33 AM
The fuel return system seems to generate among the most questions on this site, for some reason.
https://classicoldsmobile.com/forums...line-go-18789/
https://classicoldsmobile.com/forums...n-line-115794/
https://classicoldsmobile.com/forums...rn-line-23694/
https://classicoldsmobile.com/forums...urn-line-6149/
https://classicoldsmobile.com/forums...supreme-99024/
https://classicoldsmobile.com/forums...rn-line-17478/
https://classicoldsmobile.com/forums...es-help-45562/
Old May 14, 2020 | 10:48 AM
Adrian, if your fuel pump has 2 lines one is fuel OUT and the other is fuel RETURN. I suggest buying a fuel pump from the auto parts store if originality and stampings aren't important to you. You can get a lifetime warranty on a fuel pump as long as you keep your receipt. Every REAL car guy should do this for ALL of his car receipts.
Old May 14, 2020 | 11:36 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
FYI always use Google to do your initial search.
9 of 10 times it will take directly back here to the right thread.
Old May 14, 2020 | 01:12 PM
There are some variations in Olds fuel pumps (such as the angle of the outlet, the height of the housing, etc) but in general two parts cover just about all applications:
Carter M6108 - without return line
Carter M6109 - with return line
I would do as suggested above and buy the fuel pump from your local auto parts store as that makes returns / exchanges very easy. As far as brands, any should be OK.
Old May 14, 2020 | 01:16 PM
tru-blue 442's Avatar
Old School Olds
Go to any auto parts store and order a fuel pump for any 68-72 455 Cutlass, Delta, Ninety-Eight with a/c and You'll be set.
https://www.rockauto.com/en/catalog/...fuel+pump,6256
Old May 14, 2020 | 01:53 PM
My442's Avatar
Airtex 40736 is a higher volume pump.
Olds BB with A/C and return line.
Old May 15, 2020 | 07:19 AM
69442murph's Avatar
if memory serves me correctly, a 40523 is the pump that was on the 69 400.
Airtex uses the same part number, and the outlet fitting is angled correctly. Some pumps have the outlet angled wrong. At least, that has been my experience.
Snolab
Oct 4, 2015 06:47 PM
ej69
Jul 17, 2010 10:02 AM
scott_442
Nov 24, 2009 07:42 AM
Creativeindy
Aug 10, 2009 01:57 PM
amrcnmscle
Apr 25, 2009 08:05 AM
