Air Conditioner
Old Jun 22, 2020 | 11:01 AM
Gary's 2 442-S's Avatar
Gary
Air Conditioner
I have replaced the compressor and the dryer on my 68 442. I pulled vacuum on it and recharged it. I have put 52oz of r12 in it and a 4oz can of oil charge. The a/c is cool and not getting cold. I did notice that the hose that is going to the poa valve did ice up but it doesnt appear to be not doing it anymore. The high side is measuring about 160 psi and the low side is setting around 56. Is there anything else I may need to check?
thanks
Old Jun 22, 2020 | 12:14 PM
What was the ambient temperature when you made those measurements? The low side is way too high - should be 30-35 psi.
Old Jun 22, 2020 | 12:56 PM
Agree w/ Kenneth - low side ~30 - 35 psi. What is your ambient temperature. Say today it's 90°F in Houston, your high-side should be ~ 180 - 230 psi. Far too high on the low-side and far too low on the high-side. Generally, this can be the result of far too much refrigerant &/or oil added and air remaining in the system. Anyway, high-side should be x2 ambient + 50.
Old Jun 22, 2020 | 01:27 PM
Gary
It's about 85 degree here because its raining. I will take some of the freon out and see what the psi reads. I did call Classic Air and told them the POA valve did ice up and according to them that's probably the problem. They are suggesting I send my POA to them for rebuild or use a POA valve by pass. I have not decided what to do yet. As you guys know r12 when you do find it is expensive so I do have about 10 more cans of it, I just don't want to waste what I have left.
I just may convert it over to 134a or Vintage Air.
Old Jun 22, 2020 | 01:37 PM
Perhaps similar to what I went through two years ago. AC Evap Core puking green from under the underside AC not working. Replaced AC Evap Core, new compressor and new drier. Mine was converted to R34A. Frosting of the POA valve. Tried to clean POA for 3 days - no good. Ordered/Installed new POA and the AC is colder than in my newer F250 - it's frigid (like many of my H.S. girlfriends).
Old Jun 22, 2020 | 03:45 PM
Gary
[QUOTE= (like many of my H.S. girlfriends).[/QUOTE]
LOL you and I were both in the same both in high school.
bw1339
Apr 14, 2020 10:15 AM
westside807
May 4, 2016 10:56 AM
OldsManNJ
Jul 1, 2011 05:45 PM
brown7373
Feb 26, 2011 08:44 PM
Joffroi
Jul 30, 2010 10:42 AM
