Clock lens
Old Dec 26, 2020 | 10:33 AM
Dranom's Avatar
Clock lens
I’m trying to replace all the damaged lenses on dash instrument panel and all Good except for the Clock ... can’t get the winder pin thumb **** to separate in order to slide new lens Over the pin . Super frustrating and do not want to damage and then have to McGiver some sort of solution ...any tips , thoughts or input would be greatly appreciated . I’m not even clear if it’s threaded or a press tabbed fit on the thumb screw
Old Dec 26, 2020 | 11:17 AM
Yellowstatue's Avatar
Year and model would help. On a '68 Cutlass a small screw in the middle of the **** comes out and the **** slides off.
Old Dec 26, 2020 | 01:49 PM
My442's Avatar
On my 70, the clock **** was threaded on.
A small amount of heat and a drop of Kroil loosened it up.
Need to protect the shaft and **** when using pliers.
Common problem.
Old Dec 26, 2020 | 11:26 PM
Dranom's Avatar
Sorry, failed to clarify . 1972 olds cutlas
the drilled lens whole only looks of a diameter to accommodate The pin And not he black tubing that surrounds the pin but again the issue is I can’t dislodge the thumb wheel to even address that problem .
i can find no reference for this anywhere
Old Dec 27, 2020 | 05:43 AM
As my442 said it is threaded on. Turn **** off pin counterclockwise. I did mine, I think I used needle nose pliers to hold pin and turned **** with my fingers. Only problem is then it's hard to get tight enough as before and when setting clock it wants to unscrew...
GreekDog
Nov 11, 2017 06:55 AM
twintracks
May 31, 2015 07:52 AM
MJAKS462
Jun 19, 2012 06:10 AM
jensenracing77
Apr 21, 2010 07:46 AM
Olds luvr
Oct 20, 2007 04:50 PM
