Clock Lens removal
Old Nov 9, 2017 | 05:56 PM
GreekDog's Avatar
Clock Lens removal
hello everyone!
I am in the process of refurbishing my dash and gauges on my 72 cutlass. I have removed the gauges in anticipation of putting in new lenses. All of the lenses have come off easily except for the clock. The lens is caught up on the adjusting pin.
I know it’s a simple question but how do I go about removing the lens on the clock? I didn’t want to keep trying different methods because i was worried i may break the pin
Old Nov 9, 2017 | 06:29 PM
oldspackrat's Avatar
I push the rubber sleeve down just a little bit & grip the stem with a pair of pliers & then Gently unscrew the **** from the stem. If it does not come loose easily, I hold the stem with a pair of pliers & use a small torch on the **** for several seconds & then use another pair of pliers to gently try to loosen the ****. This USUALLY works.
Good luck,
Scott
Old Nov 11, 2017 | 06:55 AM
GreekDog's Avatar
Good luck,
Scott
thanks! Worked like a charm
tdhill01
Jun 21, 2016 05:46 AM
BeenThere
May 31, 2014 03:39 AM
nelsontj
Mar 1, 2011 09:00 AM
lakidd135
Aug 5, 2009 09:43 AM
Olds luvr
Oct 20, 2007 04:50 PM
