Info on 68 442's please
Old May 26, 2020 | 11:18 PM
sx455raidercelticfan's Avatar
Can some1 tell me if 68 442s have special vins 2 show there 442s and if not how can you tell if it's a 442, also what's the 400 block numbers for a 68, i just found a 68 convertible in my area it's in piece's but looks solid and it's cheap, thank you guys
Old May 27, 2020 | 03:22 AM
rob1960's Avatar
1968 was the first year that the 442 became it's own model with a specific vin. They all start with "344". Lansing built cars still used cutlass "336" trim tags on the cowl top, under the hood but the vin on the dash has to be "344" The '68 & '69 400s are "G" blocks. On the block between the oil fill tube & oil pressure sender is a block casting # which should be 396026 & right next to it is a large letter G, If it's an "F" it's a 455 & not correct for a 442( Unless it's an H/O). The heads will have a letter "C" on each end ("D" for a W30) There is a small pad on the block right below the front of the driver side head that will have the cars' partial vin stamped on it.
Old May 27, 2020 | 08:02 AM
Also, do not be surprised if the car has a 344678... VIN and a 33667 cowl tag. This was normal for the 1968-69 cars.
An FYI, however. Some of the most expensive cars I've ever bought were "cheap cars in pieces".
Another FYI, that experience has never stopped me from doing it again, either.
Old May 27, 2020 | 08:04 AM
It's a convertible, so it won't be an H/O (and no, don't bother posting the photo of the gold 68 H/O convertible... )
Old May 27, 2020 | 03:33 PM
Thanks for the info I hit them on craigslist but no response yet, its green and on Humboldt ca craigslist, just north of me
jurrasicpork
Jun 25, 2019 10:03 AM
Oldsmaniac
Oct 22, 2016 11:22 AM
Tom442
Feb 23, 2012 01:50 PM
yeahbuddy
Jun 29, 2010 09:48 AM
DR_DAN
Aug 22, 2006 02:14 PM
