PDA
View Full Version : General Questions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21
  1. Olds engine in pontiac
  2. 1962 Super 88 Fuel Tank -- Will another B-Body Tank Fit?
  3. coolant leak
  4. 2 line vs. 1 line fuel gauge sending unit
  5. 1962 Fuel Sender/Gauge Specifications?
  6. Leaking Grease out of Bottom of Lower Ball Joint
  7. 49 coupe needs driveline help
  8. Help with decoding Birth Certificate
  9. Cutlass "S"
  10. Push rod length checkers
  11. Correct fan for a Toro?
  12. Radiator Surprise
  13. '55 Rocket 88 window weather stripping Question
  14. Door Hinges
  15. Shock absorber ID source
  16. 1972 350 Heads
  17. Flat top 74 350
  18. 1967 Ninety Eight Fuel Tank
  19. Disc Brake conversion
  20. Edlebrock or Holley
  21. Stupid harmonic balancer question
  22. 1964 Jetstar 88 wiper head
  23. washer bottle
  24. Production Number for 1965 cutlass
  25. Rack and Pinion header clearence
  26. started pulling 300 amps?!
  27. cleaning chrome trim
  28. Several problems.
  29. Olds 350 1977-80 power unit
  30. Header kit for 350?
  31. 350-403 block
  32. Tanks, Inc.
  33. Help, 1971 column shift tilt upper bowl removal?
  34. fuel tank capacity
  35. Quadrajet Question--- what causes the secondaries to open?
  36. Hubcap source
  37. Cutlass 1968 - missing cowl tag?
  38. 1968 Cutlass ignition switch socket
  39. 1970 Cutlass Frame Gauge????
  40. TH400 dust shield,...which is correct???
  41. tire size
  42. Exhaust to manifold bolt size
  43. 1968 F85 cowl tag decipher
  44. 1955 Rocket 88 vacuum wiper motor question
  45. 1965 Starfire rear bumper
  46. Prep Headers for re-coating
  47. 1952 Olds 98 parts interchange?
  48. 83 H/O door window seal
  49. ribbon wire
  50. GM/AC Delco Part #Brake Combo Valve
  51. what brand parts do oldsmobiles like the best?
  52. which manual?
  53. What is this distributor?
  54. 84 olds 98, sitting 8 years, stalls under load
  55. Power steering box bolts
  56. Post door parts retrofit?
  57. Convertible trunk area
  58. GM Synchromesh equivalents
  59. 68 Cutlass cigarette lighter
  60. Front springs 70 Vista Cruiser
  61. Real W27?
  62. 1956 olds.
  63. Cruise control speed regulator
  64. What year convertible latches are these?
  65. Intake bolts wont stay seated
  66. a/c brkts
  67. Troubleshooting - 1977 Delta 88
  68. 1964 cutlass trim
  69. Roof Drip Channel Question
  70. 1925 Olds oil check valve
  71. What temp thermostat??
  72. Front inner wells
  73. '70s B and C body BBO exhaust manifolds
  74. Looking for specs
  75. 1969 cutlass supreme vinyl top trim question
  76. control arm bushings help
  77. Charlotte NC need ref for paint and engine repair
  78. 67 Cutlass Air conditioning
  79. 1969 s
  80. caster vs king pin inclination
  81. 62 starfire Gas Tank
  82. 58 olds
  83. Olds cutlass in the movies
  84. 83 Hurst Olds Speedometer
  85. '55 front wheel hubs
  86. Is there a thread with numbers listed
  87. Heat control valve
  88. What do these fit?
  89. Disc Brake Caliper Color
  90. Points and condenser change?
  91. Hood Hinge
  92. Hood trim ID
  93. Radiator Size ? 67 Cutlass
  94. Carb ID number
  95. Ignition coil Question
  96. Help Identify this Quadrajet
  97. OEM vs Repro Bumper
  98. How Difficult To Install Evap Case in A Bodies With 455?
  99. Hydraulic Window Tubing
  100. Weather stripping?
  101. valve covers
  102. 442 Stripes
  103. Manifold heat riser tube
  104. 1955 Olds Horn parts
  105. Bell Housing
  106. HEI plug gap?
  107. Rally Pack Restoration
  108. Bumper bracket compatibility
  109. lighted overflow bottle?
  110. Tire options in 1977 for the cutlass
  111. Door edge guards
  112. 72 cutlass trouble starting after getting gas
  113. Floor pan drain plug sealer?
  114. Bucket seat trim
  115. New to olds, a few questions
  116. Block Heaters
  117. evaporator case
  118. Fuel Return Line
  119. tough time with the heater core
  120. Differences between Cutlass S and Supreme
  121. coil spring installation
  122. Body Bushing Color - Found A Really Good Match, But Have A Question
  123. Cutlass Upper Radiator Support
  124. Hood hinges
  125. cowl tag
  126. 66 delta 88 fan shroud
  127. 68 442 Shifter Console 700R4 question
  128. Fan clutch question
  129. 66 delta 88 bumper jack
  130. 1968 cutlass convertible dont close??
  131. '65 Cutlass Sports Coupe Window Trim
  132. 69 Cutlass mirror options
  133. 68 442 Air Cleaner
  134. Carb Question
  135. Vista cruiser window switch
  136. Help with Headlight Adjuster & Mounting Kit!
  137. Hubcap IDs
  138. 1964 cutlass windshild molding
  139. heater box insulation
  140. who knows the company?
  141. Parts for 1954 rocket 88 2 door
  142. Halo Trim on Car Pics Needed
  143. Help Wanted
  144. 72 M-20 muncie
  145. 65-66 delta bumper jack
  146. Need Help Re-Installing 1972 Console into car
  147. Need Restoration Parts for 1972 Custom Cruiser
  148. 66 delta 88 with a/c
  149. The Unrestored 1971 442 W-30 Thread
  150. horn
  151. 1956 Olds Heater Core Removal
  152. Ps pulley replacement - save this text
  153. Oldsmobile 1964 Service Manual 1964- pdf ?
  154. 63 F85 T5 trans swap with factory console
  155. 1971 cutlass convertible rear seat
  156. 1969 f85 worth.
  157. horn contact pin went PING its gone-need a new one-64 Cutlass
  158. a/c vacuum routing 1971
  159. Front Parking light bulb replacement
  160. Need help starting a '73 Omega
  161. Motor mount bolt question
  162. Carb size for mild build on 425 BBO
  163. Best Repro Baaery Source?
  164. Car starting problems
  165. 72' cutlass replacing fuel sending unit & fuel pump
  166. 71 Delta 88 Battery Tray
  167. 78 Chevy truck headers
  168. Correct green paint for 68 455 flywheel
  169. Hoods
  170. Idle meter adjustment
  171. Dual Gate Slider Plate Tab Knob - Discontinued By Resto Parts Houses ?
  172. 1971 Cutlass - dies idling w/lights
  173. Build sheet in a 74 88????
  174. There Is A White Stripe On The Hose Going To The 70-72 OAI Motor - Correct?
  175. Oil Pressure idiot light coming on with lots of oil in engine
  176. Ok to move
  177. Aluminum 215 V8 crankshaft question......
  178. Turn Signal Cam
  179. Carburators
  180. 1964 olds dynamic need help please
  181. 70 442 Brake Drum With Rally Wheels - Is This Correct????
  182. W 30 camshaft needed
  183. Minimum flywheel thickness 68 455
  184. I need some help Id'ing some 4 speed linkage
  185. 72 cutlass sometimes doesn't start in park. Have to put it in neutral
  186. Decoding Cowl Tag
  187. Valve Cover Breathers / OAI
  188. carburetor install / adjust
  189. Repro Hoses From TPP - Any Other Suppliers Parts Any Better?
  190. What are they called & where can I buy some?
  191. Power Steering
  192. Full vacuum diagram for '61 Dynamic 88
  193. Alternator identification???
  194. Build sheet block 44
  195. OEM Starter Finish
  196. 1959 Olds windshield trim
  197. Where do I find the windshield diagram?
  198. 1972 Cutlass "S" Alignment Spec
  199. 70 442 Frame Stamping Found Today While Sanding - What Is It For?
  200. Vacuum line help on '72 Cutlass, please
  201. Photo or location for vacuum line 68 442/cutlass
  202. Help taking the trim off poat car door frames
  203. Were 403 cranks drilled for pilot bushings?
  204. i need a/c brackets , alt brackets and p/s brackets for 425 olds
  205. Frame Decoding Help Please
  206. motormount placement
  207. egr problems
  208. 75 Hurst Olds cowl to hood weather stripping
  209. 65 Jetstar I trim inquiry
  210. cutlass door latch
  211. Gass smell on 66 442
  212. R12 Compressor Overhaul/Rebuild vendor options
  213. Speedo Needle is jumping
  214. Under dash insulation glue
  215. Steering column
  216. Sparky's Does It Again!
  217. 68 Cutlass wheel and grill paint
  218. 68 Cutlass S pin stripe
  219. 68 Cutlass fuel grade and addative question
  220. How do I change points on my 1972 CUtlass 350 S?
  221. Reuse Original Upper Ball Joints?
  222. Removing speedo
  223. fenders / dash pad question
  224. cutlass door cap stainless
  225. Non fan shroud car?
  226. What was your best parts find at the nationals?
  227. 1970 Cutlass Supreme Headers Issues
  228. Possible 1967 W-30
  229. v.i.n. decoding
  230. 70-72 OAI Vac. Motor Rebuilding?
  231. 442 shifter identification
  232. Fuel pump leaking, Go Electric??
  233. Eldebrock Preformer RPM intake
  234. Another 64 core support question
  235. Horn setup behind pad
  236. Seatbelt Buzzer Question
  237. Bearings
  238. Headers
  239. Speedometer gear question
  240. gas tank sending unit
  241. TPS trouble.
  242. 82 4f014348
  243. Spark plug gap, 66 442
  244. header problems..
  245. Dash pad
  246. A/C question
  247. I have a fan shroud question?
  248. 1948 ->257 L8 Vapor Lock
  249. Air Filter Housing???
  250. Degreeing my cam
