evaporator case
Old Dec 3, 2014 | 04:41 AM
hilbily's Avatar
evaporator case
What is used to seal the evaporator case to the firewall, don't want to us silicone.
Old Dec 3, 2014 | 05:30 PM
hilbily's Avatar
WOW! No body on this site knows what to use? Don't want to use the obvious choice, silicone. Might have to take it apart some day. What ever they used originally just sealed it didn't glue it.
Old Dec 3, 2014 | 05:49 PM
Charlie Jones's Avatar
Phantom Phixer
I think the gasket was glued to the evaporator case with weatherstrip adhesive . And nothing was used between gasket and firewall.
Old Dec 3, 2014 | 08:04 PM
hilbily's Avatar
If that's the case then mine has been opened before. There was no gasket just some kind of black gukumpookie. It scraped off the evaporator easy but you can tell it made a good seal without glueing it, almost like blackjack roofing tar or wet patch or something. Anybody know?
Old Dec 3, 2014 | 08:21 PM
Yup, that's the stuff. It's a sort of a body sealant, a bit more rubbery than dum dum.
I used red exterior house caulk when I added A/C to my Chevelle when I was a kid.
Old Dec 4, 2014 | 04:19 AM
bccan's Avatar
Butyl windshield sealer aka tape or ribbon, probably 1/4", maybe 5/16". 3M & others make it. Normally in stock @ auto parts or body supply store. 3m part # 86xx.
Old Dec 5, 2014 | 03:26 PM
BlackGold's Avatar
WOW! A whole 49 minutes passes since you asked the first time -- before 8 AM! Take some Ritalin so we can go back to sleep.
Old Dec 5, 2014 | 04:39 PM
Lady72nRob71's Avatar
Look for 3M "strip calk" 08578 - it is almost the same as the factory stuff (in the 72 Cutlass at least), less the internal string.
It is in a blue box, about 20 bucks for 60 feet. I used this and it worked perfectly. I did combine two strips together around the entire perimeter for extra sealing. Use it between the 2 case halves, too.
It is tarry but hand - pliable and never hardens. Lots of other uses for the stuff, too.
Not sure what car you are using it on, but on my 72, the blower side had a bigger gap where screws were minimal. I used twice as much there and ran the blower checking for air leaks.
Old Dec 5, 2014 | 04:40 PM
Note the AM and PM...
Old Dec 5, 2014 | 05:08 PM
mrolds69's Avatar
X2...3M strip caulk is the best for this. You CAN use butyl, but if you ever need to get in there, you will be sorry you used it. Real sorry.........ever try to get a windshield out before? Imagine trying to cut your way around the whole box!
Old Dec 5, 2014 | 05:29 PM
hilbily's Avatar
Thanks everybody. Yea I was kinda worried, didn't want to glue it in otherwise I would have used silicone. 49 min? BlackGold, note the day and am pm. See,I had talked my Ritalin.
CQR
Jul 18, 2011 07:32 AM
Lady72nRob71
Jul 3, 2011 01:39 PM
KZ442
Apr 7, 2010 07:48 PM
KZ442
Nov 11, 2009 08:25 AM
jeffs 89 cutlass salon
Oct 22, 2007 12:46 PM
