Ignition coil Question
Old Dec 26, 2014 | 04:32 PM
Rocketbrian's Avatar
Recently, I found a puddle of oil laying in the intake of my SX and was wondering how it got there. It was directly under the coil. I was swapping out my carburetor today and happened to pull the coil wire out of the coil and it was damp with oil. Is there oil in the coil, and if so, could it leak out and still function?
Old Dec 26, 2014 | 04:48 PM
RandyS's Avatar
Yes to both of your questions, there is oil in the coil case and yes it can eventually leak. Replace it as it will more than likely fail soon.
Old Dec 26, 2014 | 06:02 PM
X2 with the above. It will fail very soon.
Old Dec 27, 2014 | 11:08 AM
R-body_mopar's Avatar
Question
I agree with both of the above posters, BUT:
The oil in the coil is there for cooling purposes, and if you have not lost a lot of oil, the coil may last for some time.
I was a Mopar tech back in the '70's-'80's, and it was VERY common for Mopar coils to leak, but we always took a #2 Phillips screwdriver, and tightened the screw in the tower under the coil wire, and this would usually stop the leak.......but, I'm not sure Delco has the same assembly system???
Old Dec 27, 2014 | 12:17 PM
I agree with all above: the coil will work fine without the oil UNTIL it generates a certain amount of heat, and can't properly dissipate it without the help of the oil, at which point it will fail.
I'd toss a spare in the trunk and do the experiment. If it's still in the trunk when the next owner takes possession, then there was no need to waste your time changing it now.
On the other hand, if it does fail, it will be at night in the pouring rain...
Old Dec 27, 2014 | 05:41 PM
m371961's Avatar
I would change it and keep the old working one as the spare. With new parts and my luck, the old one would fail and when I put the new one in on the side of the road it would be bad.
Old Dec 27, 2014 | 06:17 PM
Thanks for confirming my suspicions about the oil, although I didn't know it's purpose. I don't drive the car too much, so I haven't experienced any symptoms as of yet. I do believe I have a spare in my inventory of parts.
This clears up for me the puddle of oil I found laying in the intake. I suppose mounting it horizontally doesn't help the situation any.
Thanks again for the replies.
jeffsims
Oct 28, 2012 07:09 PM
GarytheSnail
Jun 6, 2012 01:07 PM
matt68
Sep 11, 2009 05:19 PM
1FSTLS1
Dec 20, 2008 05:45 AM
68conv455
Feb 20, 2008 02:36 AM
