Heat control valve
Old Dec 31, 2014 | 06:53 AM
Bfg's Avatar
Bfg
Heat control valve
Hi, I need to replace the heat control valve on my 65 442, this is the valve that threads into the rear of the intake manifold on A/C cars and has a heater hose attached. My question is does this valve interchange with a full size car with the 425?
Old Dec 31, 2014 | 08:31 AM
jensenracing77's Avatar
I believe that is the same for 65 and 66 a body or big car. I have one from a 66 98 that looks good and the valve works. I have never had it hooked up to know if it leaks water. If you want to try it I would do $12 shipped.
Old Dec 31, 2014 | 08:35 AM
rocketraider's Avatar
Oldsdruid
Oh boy. There's some weirdness with the 65 442 hot water valve. Basically both A/C and non-A/C cars have it, but on a non-A/C car they used it to reduce pressure thru the heater core and just didn't connect a vacuum source to it. That was before they figured out they could put an orificed nipple on the intake to accomplish the same thing.
That said, unless you find an NOS 442-specific piece (don't have parts books handy so can't give you the #), one from a 425/455 A/C car should work fine. Can about guarantee anything current any parts store will have will be a one-size-fits-all anyway.
Old Dec 31, 2014 | 08:57 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
4 seasons PN 47601. This fits most Olds 330 and up.
Old Dec 31, 2014 | 09:24 AM
Octania's Avatar
I know they are made two ways
1) vacuum lets juice flow
B) vacuum stops the flow of hot juice.
So, maybe if you are going to run it as a throttle valve, w/o vacuum, make sure it is open when there is no vacuum signal, before installing.
Watch the thread size too- 3/8" NPT is common thru 1967 or so, then 1/2" NPT for a bit, then 3/4" NPT later. I calibrated my hand so it's "little finger size, thumb size, or larger than thumb."
Old Dec 31, 2014 | 04:37 PM
Here are pictures. This one opens when vacuum is applied.
Old Dec 31, 2014 | 05:10 PM
jenson is there a restrictor in that unit or is it straight through?
Old Dec 31, 2014 | 05:37 PM
It is an on off. With no vacuum there is no flow. With vacuum it flows water.
Old Jan 2, 2015 | 09:36 AM
Reason I ask is I'm getting a resonance out of the heater when the temp control is moved to the hot position while cruising. Move it back to cold and sound isn't present. I've traced it to the valve. The new version from 4 seasons is restricted in the ID unlike OEM and its causing an interaction with the flow causing a very annoying woowooowooowoo at about 1700-2500 rpm. I tried drilling it out as far as possible without breaking through but no luck. Anyone else experience this or know of another company reproducing this valve?
Dream Whip
Aug 9, 2016 02:59 PM
Boilerz25
May 23, 2014 09:00 AM
jensenracing77
Mar 19, 2014 04:08 PM
smcurro
Paint
Jan 29, 2012 02:31 PM
bjtstarfire
Nov 13, 2008 02:04 PM
