Heat Control Valve Installation
Old May 22, 2014 | 08:56 PM
Boilerz25's Avatar
I noticed that the Heat Control Valve on my exhaust manifold was corroded and the flapper was actually almost completely gone. I purchase the new valve through Fusick but, I am struggling with the installation. The Chassis Service Manual has pretty vague directions. Not to mention it appears some specialized tools are being called out that I do not have at my disposal. If anyone has replaced theirs I would appreciate some advice on the process. The car is a 69 400cu in.
thanks
Sean
Old May 23, 2014 | 08:28 AM
D. Yaros's Avatar
What is the problem you are having? The install is pretty straight forward as a rule. Not certain on you application, but usually the weight arm goes toward the firewall.
Old May 23, 2014 | 08:31 AM
Boilerz25's Avatar
Dave,
The main issue is removing the existing shaft which appears to be practically fused to the manifold (will check this weekend to be sure). The other part is the initial flapper orientation when cold. I know that the flapper should be oriented then spot welded to the shaft. Does this valve function like a choke (cold/closed, hot/open)?
thanks
Sean
Old May 23, 2014 | 08:33 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
I remove the whole assembly and weld the holes closed. Also installed the riser crossover block off plugs in to my intake (welded). All in the name of performance and to lessen heat soak hard start issues. With your location Id think youd want to do the same to decrease the heat going to the intake and carb. Just my 2 cents.
Old May 23, 2014 | 08:54 AM
x2, the heat risers had always been problematic and they would stick closed causing more problems than they were worth.
Old May 23, 2014 | 08:55 AM
Boilerz25's Avatar
I think I like the idea completely. Just wasnt sure if there was real value to having it. Consider it done.
Sean
Old May 23, 2014 | 08:59 AM
D. Yaros's Avatar
You have been properly advised : Not worth time/trouble. Remove the flapper, weld it open, whatever.
To answer your specific question, yes it is like a choke; cold = closed and warm = open.
Old May 23, 2014 | 09:00 AM
x3.
If you run your car a lot in sub-zero temperatures (sub -17.7 for you folks north-of-the-border), then the heat riser can be a real help in smooth running and warm-up.
For the rest of us, who no longer drive these cars in the dead of winter, it's just another thing to go wrong.
Dream Whip
Aug 9, 2016 02:59 PM
Bfg
Jan 2, 2015 09:36 AM
jensenracing77
Mar 19, 2014 04:08 PM
smcurro
Paint
Jan 29, 2012 02:31 PM
bjtstarfire
Nov 13, 2008 02:04 PM
