Roof Drip Channel Question
I am beginning to strip the roof on my 66 project and noticed a lot of buildup in the drip channel (trim removed). I put some stipper in the channel and have come across what looks like a layer of caulk or bondo in there. Is there supposed to be some sort of sealer on the bottom of the channel, or should I clean it completely out?
As this is my first foray in to the world of stripping a car all the way to bare metal, I have another question about the roof (mostly out of curiosity). As I scraped off my third application of Aircraft Stripper, I encountered several areas where filler appears to have been applied before the original brown primer. The metal below the primer was roughed up with a disc sander. Have any of you seen that done before the original primer and paint were applied, or was it most likely done at a later date?
oldspackrat
January 20th, 2014 05:17 PM
