350-403 block
Old Feb 18, 2015 | 10:16 AM
rickracer's Avatar
350-403 block
Hey Guys, Was wondering if the 350 and 403 use the same block?
I found this picture of an OL4B installed on a 403 with HEI and was wondering if it would be the same fit as a 350.
There isn't much clearance without the cap so with the cap it's super tight.
Old Feb 18, 2015 | 10:28 AM
drop top olds's Avatar
The 350 and 403 blocks are different, but the SBO intakes will fit 307, 350 and 403 blocks. Be aware that some intakes can not accept the GM HEI distributor without some modifications.
Old Feb 18, 2015 | 10:29 AM
brownbomber77's Avatar
Short answer. No. Not the same block. But every single part except for pistons will interchange.
Old Feb 18, 2015 | 10:36 AM
Oh. And no, the OL4B will not take an HEI distributor nor will an Offenhaiser 360
Old Feb 18, 2015 | 01:44 PM
rickracer's Avatar
Brownbomber77,
I'll have to disagree about the Offenhauser 360 dual plane not fitting with a HEI distributor. That's what I've got installed on my 350 right now, no clearance problems at all, it's close but I've got about .050inch clearance by the intake runner.
If I had to change the timing I might have a problem since the screw hump in the cap might hit the runner but other then that I'm fine.
I'm thinking more and more towards the Performer RPM.
I'm wondering if some HEI's have a bigger diameter then others?
Thanks for the info on the blocks.
Old Feb 19, 2015 | 08:30 AM
So you're saying that the photo that the OP posted is a fake???
Old Feb 19, 2015 | 08:32 AM
Just for completeness, the 403 uses siamesed cylinders, unlike the 350 (or any other SBO). The blocks are completely different castings.
ALL SBO blocks are externally identical, however, so any external part (manifolds, distributor, etc) that fits one SBO will fit all of them.
Old Feb 19, 2015 | 09:53 AM
Octania's Avatar
If there is interference at the HEI/Intake, you can probably remove a little of each and gain the fitment needed. Certainly a lot of the distributor / cap can be cut away with little or no ill effect.
young olds
Sep 25, 2021 09:33 AM
88hurstolds
Jan 20, 2020 11:39 AM
brownbomber77
Jul 23, 2015 06:17 AM
import extermination
Nov 27, 2011 08:25 PM
442_rocket
Jun 7, 2008 06:27 PM
