Need Help Re-Installing 1972 Console into car
I took the console out of the car a couple of weeks ago to fix it, and for the life of me I can't figure out the routing of the lights. I can tell which lights are which, but for example I cant find where the small light to light up the gear indicator goes. There is also a small white bracket with a hole for a light to go through, and I can' figure out where that's supposed to go.
Are the instructions in a thread anywhere? I searched, but only found one for 68. :/
Well, I think I figured it out. The biggest problem is that harness seems a little short to put all the lights into place. It must be routed wrong.
The small tab that holds the PRNDLS light harness in place, that is supposed to share a bolt hole with the bracket, right?
69442C
Apr 30, 2011 02:02 PM
