Shock absorber ID source
Old Mar 4, 2015 | 05:23 PM
deaddds's Avatar
I have a bunch of Delco shocks from 60s to 80s but the part numbers are not on the boxes, just P and 4 digits. I can't seem to find a cross reference in the ac delco website. Is there a book to look for that shows the applications for Pleasurizers and Super lift shocks? Thanks
Old Mar 4, 2015 | 05:47 PM
copper128's Avatar
Lt. Buzzkill (ret.)
Try searching the part numbers stamped on the shock body. I've had better luck searching for applications that way. It's hard to X-reference older shocks because the part numbers are usually obsolete. Sometimes you have to find someone with an old catalog to look them up.
Old Mar 4, 2015 | 07:19 PM
Can you post some of part numbers off the shocks?
Old Mar 4, 2015 | 07:44 PM
orange442's Avatar
Any of them spiral shocks?
Old Mar 4, 2015 | 07:53 PM
deaddds's Avatar
No spirals. P 3041, 2084,3045D, 3049,1106,1064,1065,1093,1105,1195,1125,1085,2098, 1116,1128.
Old Mar 4, 2015 | 08:40 PM
mrolds69's Avatar
I can look them up a bit. P 1065 are 1971 88 98 rears including SW. This cat only is for 71, so they should fit others. P 1085 71 Vista rear standard + Hd susp. Ughhh...too hard for me! 1065 fits 71 Riv, too. Send me your e addie and I'll scan + send the few pages I have.
Old Mar 4, 2015 | 09:11 PM
deaddds's Avatar
dead@mchsi.com. Is there a trick to this or a specific catalog? If I search my Olds books in group 7.345, it has part numbers but not the P numbers on the box.
Old Mar 5, 2015 | 03:37 AM
Yellowstatue's Avatar
The 'P' numbers are found in AC Delco jobbers parts books, such as 5 PA-100 Jan 1968. Let me know if Dr Olds does not have all your numbers.
Old Mar 5, 2015 | 07:26 AM
mrolds69's Avatar
The easiest place to find them is the TBA catalogs, but you need a lot of them. If you have a 1968 TBA it will only cover from 67 back. When Everett closed his warehouse, I bought 100's of GM catalogs and manuals from him. Those 1065's also fit 64-67 F-85 + Buick Special, but not GS 442 or HD. #'s starting with a 1 are Pleasurizers, a 2 denotes Pleasurizer HD, a 3 is a Pleasurlift set... P 3041 are rr for 65-67 Buick All ex Riv 65-68 Olds All ex Toro + F-85. I'll toss more later........
Old Mar 5, 2015 | 09:37 AM
mrolds69's Avatar
3049...64-69 F85 All ex 442 HD + vista 66-69 Chevelle including SS 396 + El Camino 65-67 Buick Special Gran Sport 68-69 Buick Special + GS All ex wagon
Old Mar 5, 2015 | 09:43 AM
Octania's Avatar
Anyone else find the term "Pleasurizer" just a tad suggestive?
I bet this car has a real good Pleasurizer
http://www.ebay.com/itm/Vintage-ROSE...item487199a7d4
Old Mar 5, 2015 | 09:54 AM
mrolds69's Avatar
I have your e, I'll send info later. You should pull it off here or you will get spam. 3049 DOES show it fits 68 442, they are air shocks so I'm pretty sure they do fit GS , + 442
Old Mar 5, 2015 | 10:10 AM
Looks like it was designed by the same guy who designed the Edsel - Wife must've had him sleeping on the couch.
Old Mar 5, 2015 | 05:55 PM
mrolds69's Avatar
I sent the info for you.....
Old Mar 5, 2015 | 08:33 PM
deaddds's Avatar
Appreciate the info. I will start looking for those catalogs at the swaps for future use.
1969w3155
Jun 19, 2015 06:37 PM
oldspackrat
Dec 31, 2014 08:26 AM
Vyse
Jun 29, 2013 09:17 AM
joejames
Jan 2, 2013 05:43 PM
jaunty75
20
Aug 11, 2009 04:02 PM
