Rack and Pinion header clearence
On what kind of car? If you are talking about an A-body, the steering is in front of the crossmember and should have no clearance issues with headers.
Ah. Naturally that depends on where the input shaft is for the rack vs. on the stock box. I suspect you'll need to fabricate a shaft, at which point, just put the U-joints (and if needed, a support bearing) where ever they need to be.
noeatnosleep
Suspension & Handling
July 2nd, 2011 12:30 PM
