Car starting problems
Old Oct 10, 2014 | 10:39 PM
Tsandoval33's Avatar
Hey guys I need a little help. First my cutlass has a 305 4bbl Rochester carb electric igniton. Here is what happens it will start for a second then die. I will try and start it again and it will only crank. After waiting about 2or3 min I try again and it will start as long as I give it some gas. I have checked the air filter and the vacuum lines to the carb. The rotor and coil underneath the dis cap look good. What do you guys think?
Old Oct 11, 2014 | 04:02 AM
Mark57's Avatar
I would verify you are getting fuel from the pump to the carb. You could have a blockage somewhere or failing pump. I had similar issues so I pulled the fuel line from the carb and put a bottle over the end of the line. I had the wife crank the engine and found very little to no gas coming out. After confirming the pump was getting a good supply of fuel I pulled the pump and found one of the valves in the vacuum chamber had fallen out and jammed up the actuator for the baffles.
Mark
Old Oct 11, 2014 | 08:12 AM
Are you stting the choke properly?
Old Oct 20, 2014 | 01:05 PM
twintracks's Avatar
I had an '81 Toronado that acted like that. Same engine, same symptoms. It turned out to be the ECU.
Old Oct 20, 2014 | 05:15 PM
m371961's Avatar
Start at the basics, choke then fuel supply.
chasman414
Jun 25, 2020 07:05 AM
bccsrc
Nov 29, 2011 11:08 PM
bebufire
Jun 26, 2011 02:48 AM
VikingBlue
Oct 23, 2010 08:39 AM
justinj
Nov 4, 2008 10:56 AM
