Push rod length checkers
I see a few different set ups from Summit etc...which is the correct length to start with to check my valve train geometry on an Olds 350? Bored, stroked, full roller set up, aggressive cam from Mark....
I used this one from Comp Cams. My original length was 8.234" so unless yours is radically different, this should work. I didn't use checker springs but my lifters had all bled down; engine hadn't run for a few weeks. But the procedure calls for checker springs or you may bend the checker.
http://www.compperformancegroupstore...y_Code=PSHRDTL
ggriffin1960
Jan 31, 2012 10:20 AM
