Push rod length checkers
Old Mar 10, 2015 | 07:27 AM
boese1978's Avatar
I see a few different set ups from Summit etc...which is the correct length to start with to check my valve train geometry on an Olds 350? Bored, stroked, full roller set up, aggressive cam from Mark....
Old Mar 10, 2015 | 02:58 PM
speakfordadead's Avatar
I use Smith Bros. in Central Oregon. Great guys and will talk all day with you on the phone. They make a darn fine pushrod too!!! So many variables...
Old Mar 10, 2015 | 03:06 PM
Macadoo's Avatar
I used this one from Comp Cams. My original length was 8.234" so unless yours is radically different, this should work. I didn't use checker springs but my lifters had all bled down; engine hadn't run for a few weeks. But the procedure calls for checker springs or you may bend the checker.
http://www.compperformancegroupstore...y_Code=PSHRDTL
costpenn
Brakes/Hydraulic Systems
Dec 29, 2012 02:53 PM
LX89mustang
Sep 27, 2012 07:27 AM
ggriffin1960
Feb 5, 2012 07:20 PM
ggriffin1960
Jan 31, 2012 10:20 AM
defiant1
Apr 16, 2011 11:07 AM
