The Unrestored 1971 442 W-30 Thread
Old Oct 28, 2014 | 04:14 PM
Rocketguy's Avatar
Many will recognize this car's engine bay as the 10K mile '71 W-30 hardtop survivor that just sold on eBay.
I am Richard from Carcheology Restorations in SE MI and I just finished restoring a '71 W-30. What do you guys in the know of '71 W cars think of this car's engine bay?
Obviously it has many things wrong due to the manifold swap and headers, but what about the rest?
A few of my observations are:
The dipstick handle is plated and not painted.
The open faced alternator code DE is still readable, but the AM does not list a DE code part. There is also an A readable on the side.
The thermostat housing gooseneck is painted.
The routing of the fuel return line is correct, unlike many restored cars I've seen.
The upper left corner of the radiator has a dent just like the car I just restored.
The radiator top plate upper left mount is bent exactly like the car I just restored.
The holes for the washer jar on non 455 engine cars are not plugged as per the AM, nor was the car's I just restored.
The one brake line has a huge hoop in it unlike none I've seen, and the fact that it has the wire loop protector would lead one to believe it is original.
The PS return hose looks to have a double yellow stripe.
I've not seen any original master cylinder with a dual cap retaining wire, and every original car I've seen had the square type master cylinder.
Old Oct 28, 2014 | 05:03 PM
oldspackrat's Avatar
I don't know about the rest of your observations, but I believe the master cylinder is correct for the manual disc brake cars. But most of the originals I've seen had the two bleeder valves right above where the brake lines attach to the master.
Old Oct 28, 2014 | 05:17 PM
jensenracing77's Avatar
I had a 72 W-30 with 16,000 miles and it had the blue water outlet. also had a little blue overspray on the intake at the very front and just above the block.
Mine did not have the holes filled for the washer bottle either.
Old Oct 28, 2014 | 05:42 PM
oldsmobiledave's Avatar
Paging Paul Martin.
Wait for Paul Martin to chime in....he is the go to guy on these 71 W cars.
Old Oct 28, 2014 | 05:48 PM
Hairy Olds's Avatar
Shoveling Snow
Master cyl is correct.
Old Oct 28, 2014 | 06:39 PM
dc2x4drvr's Avatar
Is the left fenderwell original?
Old Oct 28, 2014 | 07:58 PM
costpenn's Avatar
I don't you can deduce any survivor type characteristics from the engine itself on this car at all. That lower alternator bracket painted engine color - means to me the engine has been diassembled for more than just adding headers & removing the "smog" stuff.
Old Oct 29, 2014 | 02:07 AM
On non A/C cars the lower alternator bracket was on the engine when painted.
Old Nov 3, 2014 | 06:59 AM
Warren Seale's Avatar
Is that master cylinder also correct for a 72 with manual front disc brakes?
Warren
Old Nov 3, 2014 | 07:05 AM
Hairy Olds's Avatar
Shoveling Snow
According to my limited and worthless knowledge -- yes.
Old Nov 3, 2014 | 04:30 PM
Rocketguy's Avatar
What a coincidence! I have a bottomless pit of limited and worthless knowledge.
Old Nov 3, 2014 | 04:33 PM
drop top olds's Avatar
double pumper carb? Holley?
Old Nov 3, 2014 | 05:41 PM
Mr Shifty Sidney's Avatar
This car was just over an hour from my house. I was going to go and take pictures but never did. If anyone knows where this car goes I would like to talk to the new owner.
Thanks,
Don W
Old Nov 3, 2014 | 05:43 PM
71-72 non power disc use the dual clip master cylinder as shown. Now if I only knew what code was stamped on them.
Don W
Old Nov 4, 2014 | 06:10 AM
There are two types that appear to be available. The one on the bottom is what is shown in the 71 W30. Which one is correct?
Warren
Old Nov 5, 2014 | 04:57 PM
The master cylinder that I have is like the one on the bottom. The only differences that I am seeing is the amount of metal around the back brake line port. I believe the master cylinder I have is an original GM unit, but not necessarily from a 71/72 W-30.
Don W
rcktdoc
Feb 29, 2016 07:51 PM
ros6872
Oct 29, 2014 10:57 AM
ros6872
Aug 13, 2014 09:45 AM
auto_editor
Apr 13, 2011 04:06 PM
oldsdroptop
Jun 1, 2010 03:28 PM
