- Removing Rear Qtr Window/Regualtor
- Rear frame braces
- 1972 Olds Cutlass/442 Assembly Manual - PDF format
- Bumper Question for a 66 Dynamic
- 442 cutlass distributor
- Original Style Passenger Mirror 1970 Cutlass
- Difference between Heater Appliques with A/C and Rear Defogger
- 1970 442 inspection
- front springs
- Headers 68 cutlass supreme
- Torque Converter Manufacture
- 65 442 fuel line replacement
- Converting single exhaust to dual '59 98
- 87 Delta stalls without warning
- Painting parking brake asm
- Why does HD Cooling need different Generator
- 70 cutlass carpet underlayment
- Throttle Cable Bracket for ?
- Where do these bolts (copper?) go?
- Where do I find a Stock Waterpump for my 425???
- is it hard to build my engine
- Ranmat
- 1956 olds 88 holiday 4dr hardtop windshield help
- rocker arm studs
- Heads
- Wheel Alignment
- Floor Pan Fitment
- 62 olds 394 to 455 conversion info
- Anyone have a copy of a G-body Pre-delivery checklist?
- Questions...turnsignals....fanblower
- 61 Starfire supplement
- What kind of fluid do I use 67 conv. top pistons?
- A/c delete
- 1988 Toronado Trofeo rear Suspension Sits Lower Than The Front
- Starter
- Welding around control arm mounting hole with arm attached?
- Polish interior dash paint question
- W27 cover, original or repro?
- 70 442 Gold Interior Headliner Pattern?
- Disc Brake Conversions for 65+ B Body Olds????
- Fuel gauge/tank sending unit
- Differential question
- 61-63 F85 Trunk Latches & vacuum actuator
- Distributor won't come out
- Its my car a 1957 oldsmobile super 88 holiday or just a super 88?
- dash, header, and exhaust question
- Holley 4175 Spreadbore ?
- GM Part #'s for headlight housing parts (springs, plastic adjusters)
- Power steering hose bracket
- Power to Manual Steering Conversion
- Are there U-Tube monitors??
- installation help needed 70 Cutlass sport mirrors
- Valve Stem Length 1964 330?
- 1959 oldsmobile engine breather tube
- Engine cranks, no start
- Muffler
- Trim Code
- 1965 442 frame bracing ??????
- carbs
- 69 cutlass disc/drum brakes ?
- CONNECT MY DOTS? Took steering box out...forgot what goes where now -w. Pictures **
- Gravel guards?
- serpentine conversion
- 1965 442 suspension
- 1970 442 Engine
- Service manual
- kick down not working propperly anymore
- Roller Cams?
- very little fuel to carb
- convertable top
- Engine code breakdown
- 56 olds distributor has no markings
- sensors
- Assembly manual
- Antenna change
- 55 Olds 98 with one too many floor buttons?
- Heat soak causing hydrolock ??
- o.a.i. hood springs
- Quadrajet 4 barrel 7025255 cfm specs
- Radio help
- rockers etc. 455 motor/ no start
- Recall Notice from ILT...
- Steering box decal
- Transmission question
- Wiper arm removal?
- do these tires make my car look phat?
- convert boot
- going crazy over oil leak
- Lighting rod shifter question
- E heads
- 68 Delta paint
- Weight: Cutlass S vs Supreme
- lighting problems-71 cutlass
- Squish or Quench
- Hybid Oldsmobile? Not what your thinking...more like Frankenstien
- Recommended tools for a restoration
- How many here with headers...
- p.s. pump pulleys
- Shoulder Belt 72 Supreme Convertible
- Tires for a 1973 Delta 88
- 72 OAI Questions
- repro door hinges
- 56 Olds Firewall Support
- Dual gate Shifter question
- heater fan wire
- Tail lights
- Fuel Vapor Line Wrap - What Is It And Where To Get?
- 65 starfire deck lid
- cam bearing removal
- drum to disc
- Brothers auto parts
- An Article: Gross vs. Net Horsepower Ratings
- 69 sport mirrors
- 1965 F85 holiday coupe
- kickdown cable th350
- 1967 Delta 88 Vacuum Line diagram
- 67 Cutlass Fuel Gauge Not Working
- How To Attach New Fender Well Flaps?
- Fuel pump up or down?
- valve covers
- tach & clock rebuild
- painting aluminum valve covers
- HELP - Site LOcation of 1966 Cutlass Assemby Manual
- heater hoses
- Troubleshooting 1972 Cutlass before it's my daily driver
- Car starts by dash electronics are dead
- Took the Car For a Cruise, New Problem
- Glass Bowl Fuel Filter
- rear veiw mirror too low !
- Window trim
- Frame Mounts help
- vent lines
- Wheel base 1970 442
- 403 intake on 330 motor
- Valve spring damper - int. or exh.?
- Cutlass trans oil cooler and A/C
- help on identifying engine
- help with radio removal 1976 Regency
- Rough Idle when put in gear
- 1966 F85 Quarter Window Seals and Chrome
- Replacement V I N tag
- 1966 key activated alarm.
- 1957 Olds Generator & Build Dates
- Door jamb vin decal
- Trim
- Battery trouble
- Sport wheel horn contact repair kit inquiry
- Gas tank sending unit..
- Converting Tranny the Right way
- 1956 Olds Gas Filler Tube
- Two part numbers needed
- rechroming pitted pot metal mldgs
- Qjet choke problem
- Air from floor outlet
- Could someone explain this cowl tag?
- Fuel tank sock... 66 Toronado
- Correct 4GC Carb?
- Cowl tag ID mystery
- 1961 ols 88 to 1962 starfire interchange?
- Old Carb Vaccum lines???
- rochester 4gc carb....
- Harbor Freight 1 ton foldable engine hoist question.
- Windshield Washer jar rebuild
- got it runnin, now new problems
- a/c help
- Great need of info and help on 394
- I need hei for a dumb *ss
- Southeast car club
- Double Hump Crossover
- lifter knock after 10 years of sitting???
- i got the car to run after 10 years sitting..
- 442 Hood real or repro???
- How to change the break fluids?
- What is this?
- '72 350 Quadrajet 4MV hard start when motor is hot
- 68 442 help needed.
- fuel line installation
- Whine/Buzz when turning key (coming from key area) after starter replacement...
- Front and rear window trim istall?
- Convertible top replacement
- Valve stem too short
- Which wire? Radio! AM/FM
- Engine i.d. # 3955582
- 68 cutlass wipers stay on
- Key issue on Vista Cruiser
- Fan shroud lower nuts - seized?
- 72 Seat Belts - Again
- Pinch Weld Removal 72 442 Conv.
- Kick Panel Removal - Please Help
- 0 Compression in #1 Cylinder! 455
- Speedometer changes with rear end swap
- Stupid Questions
- power locks help? switches?
- 1965 330 uhc
- casting number
- 67 cutlass with a 425???
- Casting number for intake manifold for '70 Rallye 350?
- Paint Code for '70 Rallye 350 Sebring Yellow?
- Rebuilding '72 350 4BL for mileage/daily driver
- 65 starfire relay.
- Trunk lock
- 1965 Dynamic 88 convertible rear brake drums
- Need proportioning valve for 69 Cutlass
- also need help decoding cowl tag
- Cowl tag help
- decoding hurst
- 59 Oldsmobile dash
- 65 trunklid
- vert tops
- buick 455 in a delta 88
- 70 OLDS. 3spd.
- synthetic oil in a 455
- 71 Olds 350 Piston/valve Clearance
- '66 Quadrajet Issue
- 68 hard top 5 bow headliner interchange
- Decal locations
- Decoding a '71 442 VIN
- 1968 cutlass exhaust manifolds
- one more question about my 64 f-85 manuel transmission
- figuring out what transmission came in my 64 f-85
- 4 door starfire?
- decoding 64 cutlass cowl tag
- decoding 1964 olds cutlass cowl tag
- decoding 1964 f-85cutlass cowl tag
- More Fun with Brackets
- jaygeedon
- There is water, IN MY DOOR?
- Some BUGS...
- 1968 442 base equipment.
- clutch fork lengths
- Tachometer installation question
- 69 olds 455 lansing built
- 68 dashboard
- Stud pattern measurment
- Air Conditioner Filter
- Window trim help
- vacuum lines
- Service manuals
- 750 or 800 cfm carb?
- Exhaust System Noise Control
- still having starter problems 64 dynamic88
- date codes for heads
- 1970 SSII 13inch
- Changing the stearing column difficulty
- 68 serial # and body tag don't match
- 1968 Cutlass Intermediate Steering Shaft
- Need Help Installing Refrigerant Oil in Rebuilt AC System
- Power bucket wiring
- GM foil decal
- has anyone ever used DuraCool refrigerant
