heater fan wire
Old Sep 17, 2011 | 07:32 PM
craftsman1956's Avatar
heater fan wire
Does anyone have a pic of the wires attached to the heater fan switch/heater control unit I can see? The top spade does not have a wire and the fan won't run and I can not find a wire to use there.Is it a hot wire? If so i could splice into a hot wire to go to the switch.Also,how many decals go on the fan shroud on a 72 350 4bbl automatic? I have seen pics of one to 3 decals,and where on the valve cover is the decal placed?Are there any decals inside the drivers door jamb? Thanks!
Old Sep 17, 2011 | 08:09 PM
Lady72nRob71's Avatar
Assuming this is a heater only car?
What are the colors of wires you have on the switch?
Not certain about the decals. I do know there is supposed to be one ont he door jamb with the VIn and stuff. Also I know there is supposed to be an emission / tuneup label on the shroud.
Old Sep 17, 2011 | 08:42 PM
First, with the wires for the heater switch
open this link and go to page 1-12. This is a pdf from the website Wild About Cars (free membership - free use). It shows the answer to the wiring question you have. http://wildaboutcarsonline.com/membe..._Section_1.pdf
1. Decals on fan shroud? 0 All decals go on the rad top plate or rad support. You could have a coolant servoce decal (left side) on the rad support close to the rad cap. There's also a decal seal for the rad cap. Decals that go on the rad top plate would be the one for cooling system and one for the emmissions decal.
2. Assuming you are talking about a 72, there are no decals on the VCs
3. Decals on the door jamb - No, but there are decals that go on the rear inside of the door.
The blue gm production decal that has the VIN and the GVWR. Front / Rear. If the car was a Canadian export it will also have the Candian certification (985) sticker. Some people put a blue reflectorized GM sticker on the door
Scroll through this link and you'll find all the details about decals / stickers. Although for 71 its bascially the same for 72. http://wildaboutcarsonline.com/membe..._0__Part-2.pdf
IMG_1474.jpg?t=1305947340
2008_0314MILLER0008.jpg?t=1254857798
Not that easy to see bu the decal closest to the engine is the cooling system decal, the one closest to the front is the emissions, the one to the left is the coolant inspection. The air cleaner has the 350 rocket and the AC Delco cleaner info.
emissionsdecalandcoolingdecalsjpg.jpg?t=1254857187
Old Sep 18, 2011 | 03:53 AM
Thanks,this is what I was looking for.I only have 2 of these decals so I will get the rest from drdecal. And my car has a/c.
5998DownUnder
Jun 9, 2014 09:35 AM
tinner
Aug 17, 2012 05:29 AM
superstingray77
Jun 27, 2011 06:13 AM
Joel
Apr 12, 2011 02:58 AM
68cutlassdriver
Mar 6, 2011 11:53 AM
