65 starfire relay.
65 starfire relay.
still looking for a relay, for 65 starfire ,all b - body,s must fit ,its the one for the power windows and power seat, to the left under kick panel.the one i have is powering the seats but not the window switch , can,t figure it out,oh well ,please help.thanks will.
It is not too clear but the way I read the diagram, that relay only powers the windows. The power for the seat comes directly from a circuit breaker. Does the power antenna work when you turn on the key? (maybe you don't have one) That relay and the antenna both work through the same fuse. Do you hear the relay "click" when you turn on the key? Are you lacking power only to the main window switch or to the individual windows also? I would have to look but I think I have a relay. I'll watch for your answer. Bruce
relay
thanks for the reply,no power antenna,but have power with a tester at the fuse box where it says antenna,i must of messed up the relay when i tried to fix it, i sodered a little piece of the windings in side ,it had broke away,it is good to know the seats are on a different fuse, atleast i have it half way there, i had taken harness out as i was restoring car, if i put a tester on a ground and touch the relay it will make the klicking noise , i think power is coming out of one side , i will do some more testing tonight ,and thanks again,i will gladly take a relay if you have one ,just let me know what you are asking , i am also looking for a lower half of the back seat ,if you know of any, thanks will.
