serpentine conversion
Old Nov 12, 2011 | 01:45 PM
rodan's Avatar
Question serpentine conversion
does anyone know what car or motor I can get the pullys to convert my 69 olds 350 over to a serpentine system?
Old Nov 12, 2011 | 06:50 PM
Rickman48's Avatar
Used to be a place in Lagrange, Il. - can't remember the name, but gives google a place to start!
Old Nov 12, 2011 | 08:18 PM
arodenhiser's Avatar
STOP call'n it a Chevelle
I haven't used one before but I was looking at this one a while ago.
http://www.marchperf.com/olds_350rocket.html
455 kits are more common.
_
Old Nov 14, 2011 | 03:55 PM
This comes up regularly. The March system is NOT a true serpentine system, but at least it's extremely expensive...
The only Olds motor that used a true serpentine system is the V6 diesel. There were two versions of the brackets, one for FWD and one for RWD. The RWD version will bolt to any 65-90 Olds V8. Good luck finding one in a wrecking yard.
You CAN buy the reverse rotation water pump used on those motors, however. Some folks have adapted the cast brackets from an SBC for accessory mounting and used the diesel pump.
Old Nov 16, 2011 | 05:47 AM
O.P.LARRY's Avatar
Here is a link to something that FE3X and myself are working on.The details are in the thread.
http://www.oldspower.com/vb/showthread.php?t=58561
rcdynamic88
Oct 20, 2014 09:44 AM
lowrico
Aug 10, 2011 07:01 PM
400mphpc
Nov 12, 2009 12:02 PM
troys2222
Oct 4, 2007 03:53 PM
snowri
Mar 29, 2006 04:36 AM
