Cutlass trans oil cooler and A/C
Old Aug 19, 2011 | 03:15 AM
texasred's Avatar
Tom Servo's Stunt Double
Does anyone have a 70-72 Cutlass (mine is a 71) with factory A/C and a transmission oil cooler? How/where did you fit the oil cooler? In front of the condenser? Between the radiator and condenser?
Is this even possible or am I going to have to make a choice between comfort and durability?
My car is in pieces right now and I'm looking for a clue card.
Thanks in advance.
C.J.
Old Aug 20, 2011 | 02:56 AM
rustyroger's Avatar
'87 Delta 88 Royale
Put the cooler in front of the coolant radiator and condensor or you will be blowing hot air over it.
Of course if you do that warm air will be passing over a small part of the condensor and radiator but as long as they are both in good shape it won't matter.
I have always fitted trans coolers so they return via the original heat exchanger in the coolant radiator, the instructions on all the kits I have bought and my local transmission shop recommend doing it this way.
Roger.
Old Aug 20, 2011 | 03:44 AM
texasred's Avatar
But is there enough room between the condenser and front end bits on a Cutlass?
C.J.
Old Aug 21, 2011 | 03:00 AM
rustyroger's Avatar
'87 Delta 88 Royale
I haven't fitted one to an early '70 Cutlass but I've never come across a car that didn't have enough room to fit one.
I have fitted some to modern fwd Euroboxes with their overcrowded engine bays, the main problem being often having to remove some of the front end (bumpers, grille etc) to gain access.
I don't think you should have any major issues with your Cutlass, one of the delights of older American iron is having plenty of room to work in!.
Good luck;
Roger.
Old Aug 21, 2011 | 06:23 AM
Boldsmobile's Avatar
Courtesy of ROP
http://72.22.90.30/phpBB2/viewtopic....mission+cooler
Mike H.
Dec 12, 2013 08:23 AM
78ChevOlds
Aug 27, 2010 10:31 AM
68conv455
Jan 3, 2009 11:53 AM
bjtstarfire
Dec 13, 2008 08:48 PM
