Stupid Questions
Old Jun 22, 2011 | 09:05 AM
swesson's Avatar
Stupid Questions
Hi all, I am currently restoring a '68 Cutlass Supreme 4dr I have some questions some of which I feel stupid asking but I know all you helpful folks on here won't mind.
How do I know which trans is in it?
How do I know which rear end is in it?
I am in the process of removing the engine with the intention of reconditioning it does anyone have any recommendations what to do with it when it's out i.e. should I put a high lift cam in or new pistons, heads etc. As far as I know it's a stock 350 rocket with 2bbl carb.
Hopefully you guys can offer me some advice.
Old Jun 22, 2011 | 09:06 AM
swesson's Avatar
oh and also did they ever make a 4dr 442?
Old Jun 22, 2011 | 09:19 AM
No, but YOU could .
Old Jun 22, 2011 | 09:21 AM
swesson's Avatar
yes that's what I thought.
Old Jun 22, 2011 | 10:07 AM
halfmoontrail's Avatar
YES, the Pursuit Package was available on the 4-doors in 1965 only.
An easy way to determine what transmission is looking at the shape of the transmission pan. Most likely ST300/Jetaway (anyone have a pan picture?) or Turbo 350 (rectangle with one corner cut off), possibly Turbo 400 (shape of Texas).
Rear end ratio will be identified by a stamped code on the passenger side axle tube, either side, somewhere between the center chunk and the brake assembly. Use a wire brush to find it.
The '68 Rocket 350 is a good motor, you could have a very reliable and powerful motor merely by putting on a used factory 4-barrel intake with quadrajet, and dual exhuasts. Headers are also a good value. Add a HEI distributor from a junkyard, and you've got a good runner for low $.
Steve
Old Jun 22, 2011 | 10:10 AM
Uh, wrong year listed, that should be 1964, in which 10 were reportedly built.
Old Jun 22, 2011 | 10:26 AM
That was 442 equipment, not 442 trim.
It didn't say "442" on it.
Old Jun 22, 2011 | 10:29 AM
You are right, and I am wrong. Thanks for the fact check.
Steve
Old Jun 22, 2011 | 10:30 AM
I've already been wrong once in this thread, but here goes...I think the 4-door '64 442's did have 442 emblems.
Steve
Old Jun 22, 2011 | 10:47 AM
Well, maybe it's my turn to be wrong then.
Joe knows.
Hey, Joe! Are you out there?
Old Jun 22, 2011 | 10:52 AM
The '64 4dr 442's also had the 442 emblems on them from what i know, but the police pursuit pkg was available to law enforcement, and perhaps the general pubilc as well.(I know it was later on Delta's, just not sure about the early years to the public).
Old Jun 22, 2011 | 10:58 AM
Old Jun 22, 2011 | 11:41 AM
rocketraider's Avatar
Oldsdruid
EZ way to tell your trans- if it says PRNDL it is a Jetaway, PRNDSL is a Turbo 400, but that was only available in Vista Cruiser and 442 in 1968 A-bodies. A Jetaway is not a Chevy PowerGlide by another name- it is a very different transmission.
There will be a two-character code stamped into the RH axle tube that ID's the gear ratio. It should be on the back side of the tube, but I've seen the things stamped all around it.
A 1968 Supreme should have a 4-barrel 350 with 10.25 compression, though the 2-barrel 9:1 CR was optional.
Old Jun 22, 2011 | 11:42 AM
Doesn't prove it had the emblems, but it's close enough for me.
I retract my earlier statement.
Old Jun 22, 2011 | 04:43 PM
The 1964 more-door 442s did have emblems. The bigger question is, how many B09 police cars were built with exactly the same equipment and WITHOUT emblems?
As for the 1968 in the OP, the only automatic available in that car would have been the ST300 (aka Jetaway) two speed. The TH400 was only available in the 442 and the Vista Cruiser that year (and I suspect the VC trans was really the lo-po TH375 version when used behind the 350 motor). Of course, the trans could have been swapped, but an original would have been the Jetaway.
Old Jun 23, 2011 | 01:33 AM
rustyroger's Avatar
'87 Delta 88 Royale
Something a senior NCO told me when I joined the Navy - "It's not a stupid question if you don't know the answer".
What this forum is about surely, to help us all learn more about our cars.
Roger.
Old Jun 23, 2011 | 01:53 PM
snowballs442's Avatar
Resident Eskie
None of these questions were stupid, I think we all learned something. Welcome to the site and keep us updated on what you are doing with the car.
Old Jun 24, 2011 | 12:25 AM
swesson's Avatar
Thank you all for your help and advice. Doing a bit of bodywork on it this weekend then hopefully pulling engine and trans next week. Will post some pics soon.
sz3gfj
Jun 14, 2013 06:45 PM
auto_editor
Apr 26, 2013 05:19 PM
MDchanic
Mar 27, 2012 07:54 PM
Tedd Thompson
Sep 24, 2010 07:32 AM
gearheads78
Dec 18, 2009 06:15 AM
