Tail lights
Old Sep 16, 2011 | 06:55 PM
RABs32's Avatar
Tail lights
I've got an 86 442,The problem I have is if I step on the brake pedal the right rear tail light goes out and the reverse lites come on and I have no right side turn signals and the turn signal indicator lights in the dash are not working also,Left side is okay.I have checked all the bulbs to see if they are the correct ones and the only other thing I've done recently was put in a new gas tank.Any advice would be greatly appreciated to help me get me started in a direction to correct this problem.......THANKS,Rich
Old Sep 16, 2011 | 07:04 PM
Lady72nRob71's Avatar
Did you disconnect or pinch any wiring or grounds when you were doing the gas tank?
SOmetimes it is easy to do without knowing.
The reverse lights are completely isolated from the brake lights, so i sense a pinched harness or such
Old Sep 16, 2011 | 07:48 PM
RABs32's Avatar
The only wires that were in the area were for the gas gauge and it's working......Rich
carnell71075
Apr 12, 2015 04:09 PM
Oldssupreme
Apr 3, 2015 08:36 PM
JATA
Jul 10, 2013 06:46 AM
oldstuff
Sep 13, 2011 08:03 AM
Sid
Sep 10, 2010 02:33 AM
