also need help decoding cowl tag
Old Jun 8, 2011 | 03:46 AM
OldsManNJ's Avatar
1971 Cutlass S
I looked on the web and am having some issues decoding my tag - hoping some of you can help me out.
ST 71-33687 R16954 BDY
TR 948 61 E PNT
06D150
Thanks to all who may respond...
Old Jun 8, 2011 | 04:52 AM
jaunty75's Avatar
The 06D means it was built in the fourth (D) week of June (06) of 1971. That's the extent of my ability to decode these. Others on here have the rest of the codes and will likely chime in soon.
Old Jun 8, 2011 | 05:05 AM
71= 1971
3= Oldsmobile
87= 2 door Holiday coupe
Don't see 948 interior code but 947 is white interior
61= Sandalwood paint
E= Sandalwood vinyl top
Old Jun 8, 2011 | 05:17 AM
GAOldsman's Avatar
"Car"mudgeon
Original Body color - 61 = sandalwood
Top color - E = sandalwood
Interior trim color - 948 = sandalwood bench front seat
33687 = Cutlass S Hardtop Coupe
not sure on the 150 after month and week code
Scot
Old Jun 8, 2011 | 11:44 AM
OldsManNJ's Avatar
1971 Cutlass S
Thanks to you all -
Old Jun 8, 2011 | 12:03 PM
rcorrigan5's Avatar
Randy C.
ST 71 = style/model year = 1971
33687:
3 = GM division = Oldsmobile
36 = model series = Cutlass S (V-8)
87 = body type = hardtop coupe
R = assembly plant = Arlington TX
16954 BDY = assembly plant body number (internal plant use only)
TR 948 = trim number (interior color and front seat type) = desert gold interior with a split bench seat
61 E PNT:
61 = lower body color = sandalwood
E = upper body color = sandalwood vinyl top
PNT = paint
06D = time build code
06 = June
D = fourth week of that month
The build date of your car is the fourth week of June 1971, a late production car
150: I suspect this is an option code of which I do not have the break for it.
Randy C.
Old Jun 8, 2011 | 05:50 PM
GAOldsman's Avatar
"Car"mudgeon
Randy C.
1971 Oldsmobile Cutlass 442 (27mb) This link is from the GM Heritage Center and has a ton of good info for '69 - '72 Oldsmobiles even though it says Cutlass and 442 it has some docs within that covers B & C bodies as well. With that being said look at page 240 and there is no desert gold for trim color in '71, 948 = sandalwood color interior trim. Hope this helps and not confuses.
http://www.gmheritagecenter.com/gm-h...tion-kits.html link to Heritage Center just click "show" next to Oldsmobile
Scot
Old Jun 8, 2011 | 07:45 PM
rcorrigan5's Avatar
Randy C.
Thanks for the heads-up, Scot. I have annotated my reference book accordingly!
Best Regards,
Randy C.
Old Jun 8, 2011 | 08:04 PM
GAOldsman's Avatar
"Car"mudgeon
No problem at all, I am always glad to help if I can.
Scot
Old Jun 9, 2011 | 04:14 AM
OldsManNJ's Avatar
1971 Cutlass S
Thanks for clearing that up - I was beginning to wonder since I had two opinions about interior color. My interior is sandalwood - with a brown dash. Is that the norm for a sandalwood interior?
I really want to take the car back to stock color, but my wife loves it red - I am torn about what to do as I perform the little bit of bodywork this needs and planning on paint...
Scot
Old Jun 9, 2011 | 07:50 AM
GAOldsman's Avatar
"Car"mudgeon
No problem at all, I'm glad to help. Yes a painted dash to match as close as possible to the upholstery color. Here is a link for paint codes and color chips for your original colors. Page 1 is exterior colors and page 2 is interior colors.
http://www.tcpglobal.com/autocolorli...obile-pg02.jpg
That will have to be answered by both of you. To each his/her own, built it so you'll enjoy it.
bigrockingd
Jun 1, 2016 06:00 AM
buzz lightyear
Jan 14, 2012 09:30 PM
rallygreen
Sep 15, 2009 04:02 PM
NorCalAndy
Feb 24, 2009 06:43 PM
DesertToro
Jan 16, 2007 07:10 PM
