- Distributer drive gear roll pin
- Starter is shot
- OK, I'm stumped
- Engine bay light harness location help
- 61 Starfire 4GC Part Number
- 1971 Cutlass 350 4 barrel fuel injection conversion advice
- 61-64 Starfire A/C availablility-stallation
- correct rear end and code
- Heater Box Internal Flap Seals Replace
- Help! My carb trickles Gas at idle???
- Outer Door Weatherstrip Dew Sweep Interchangeable???
- Interchangeable Bumper?
- Rocker Arms
- 442 Rear bumper exhaust cut outs
- Convertible top
- Blown head gasket?
- 134A Refrigerant
- Convertible boot
- A/C Help Needed
- Help with 66 throttle linkage
- 371 extra capacity oil pan on ebay
- Dealer installed antifreeze decal location
- Steering wheel off center?
- Manually open top on 71 cutlass
- Fuse Box Connection for Power Seat Feed Wire?
- Any issues with Phoenix Graphics customer service?
- Please help me buying tools!
- 62 Starfire A/C and heater vacumm lines
- 1971 CUTLASS AC Compressor to lines "O" rings
- 71 Neutral switch
- Electronic ignition tuneup
- Will some1 decode this please
- 1964 olds cutlass 330 4v
- 442's registered in Ontario Canada
- coolant change
- cutlass 66 radiator coolant level
- Molding identification
- PC tag 4 row Manual radiator
- Rebuild/update radio question
- Vacuum trunk opener potential malfunctions
- 4GC differences / interchangeability
- 4-Way Power Seat Adjuster '70 Cutlass
- Any1 have pics of oai latches/bumper stops
- Coil spring tags
- Again need H.E.L.P. On frame rear rails switch ????
- Need H.E.L.P.
- Info on shifter ball I found
- Intake Manifold ID #'s
- 70 442 Wheel Recommendation
- Vintage Mallory Points
- '70 Cutlass headlight surrounds - drop the bumper?
- Front bumper have to come off to remove the horns?
- Best way to rebuild my 1971 350 Rocket
- Thornton header fit really tight - need opinions
- 1970 OAI hood painting - tooth installed first?
- Heater switch knob
- 72 cutlass ignition switch
- Hood question
- Informational Bulletains
- 1980 442
- What do 170 Series Qjet primary rod letters mean?
- Central PA Shop Recommendation
- Assembly manual quality??
- 1955 88 2d HT
- 1955 88 2d HT
- Terminal wiring Rallye Gauge
- Glove box hinge/hardware?
- Air Conditioner
- Internal Engine Rust: Clean and Flush Products?
- convertable top rear window
- 1966 330cui exhaust manifold
- Power door lock/window wiring layout?
- Parking Lamp Replacement
- What cam are you using?
- Looking for Tool Advice - Leak Down Tester
- Exhaust dead end
- 72 Cutlass fuel tank
- 70 brake booster/ master
- Mechanical Furl Pump Help
- 70 Cutlass Sport Bullet Mirror Adjusters
- 66 v8 distributor
- 72 Rear Power Window
- Correctly restored Wiper Motor
- What is this?
- Vacuum Advance Control Specs
- Quadrajet ID number for 1969 442
- 70 - 98 Power Seat Problem
- Name that bell!
- Lower Rad Hose
- Knocking under braking and acceleration
- Flywheels
- Distributors
- UHV Application Guide?
- Fan Identification
- Which Compression/Leak Down Tester?
- Info pls, weight of bare 455 and shipping info
- 68 442 turnpike cruiser questions
- Rear Power Window - 72 Convertible
- Lock Hood
- Factory Vacume gauge
- flexplate
- Please help - Decode 71 Olds Cutlass Cowl Tag
- It's been a tough month for friends and relatives
- Info on 68 442's please
- Air Cleaner Identification
- Air Cleaner #3
- Another Air Cleaner
- Air Cleaners Ahoy!
- fresh 455 build tune up help needed
- Need Help Identifying Air Cleaners
- Carb sizing vs head flow #s
- radiator shroud question heavy duty
- need some help
- 1967 Phoenix Graphics Stripe kit
- What is this wheel from?
- Oil pressure warning light.
- 69 442 Bumper question
- 1965 tail panel
- Need vacum hose diagram 1970 olds 442
- Fuel Pump question: 69 400ci
- Need Help Identifying Part on 1968 Cutlass 350
- Is The AC Muffler Really Needed??
- Door Latch 67 Cutlass
- Where to Install Second Coolant Temp Sensor for EFI
- 72 Supreme - Mufflers Recommendation
- Radiator seals..
- 1968 Cutlass S Gas Vent
- A/C hose assembly
- Repair or replace - Lower rear shock mount
- throttle position sensor "still" showing code
- Vehicle id before vin
- 64 cutlass wheel well trim repair
- Repositioning 71 455 points distributor
- Accelerator pedal questions
- Are these all the same?
- Ported or Unported Vacuum Advance-Dist ?
- please help identify 1950's convertible power window regulators
- Height of Power Bucket Vs Manual Bucket 72
- duel point distributor w/ mechanical tach drive
- Manual Brakes vs Power Assist
- Comfortron
- 14x6 steel wheels
- 1964 Olds Cutlass holiday coupe resto
- Engine fitment for my 1979 “rocket” 350 in a 1984 g body
- Best place to buy parts
- Air Conditioning question
- Rear harness guide/guard?
- gaskets
- Rebuilding Lifters - Yes or No
- A/C Delete and heater box cover plate
- 70 supreme build sheet question
- diesel starter
- What is this relay looking thing?
- Oldsmobile cutlass ciera 1988 3.8
- 69 w30
- 69 w30 4-speed
- Brake booster. Late 70's gm B body ?
- Electric fuel pump fuel tank
- 67 seat belt bolts
- Correct radiator replacement
- Cutlass decal for 69 Cutlass
- Led bulbs?
- 1966 Oldsmobile A/C
- 1970 442 Piston question V or U notch tech questions
- Self tapping carb inlet filter for Rochester QJ
- 70 convert trunk question
- Help with part numbers
- Weight of E Heads
- 66 442 HD Cooling Fan Clutch Recommendation
- Glove box lock removal without a key?
- 62 olds dynamic 88 engine block aqua green paint
- 330-425 valve cover baffles
- 71 Cutlass HVAC rectangular hose
- 1969 cruise control - revisited
- 72 350 Supreme Breather Question
- 68 Cutlass S Steering Column
- 1968 / 1969 speedometer differences?
- 89 regency 98 water pump replacement
- 1970 Cutlass Fuel Tank Vent Hoses
- Hurst Dual Gate 2 neutral safety switch (68/69 Cutlass)
- Carb help
- Lower steering column bearing
- 1968-1969 Cutlass blower-type rear window defogger
- Rear Brake Lines and Hose Assembly - '70 Cutlass
- Mysterious vacuum can
- interior windshield defrost vent duct tube housing?
- Mallory distributor ID
- newb post about finding general parts for Rallye 350 from chain stores
- 1968 rear side marker lights
- Oil change
- Need 1968 Oldsmobile A-body non-tilt floorshift steering column diagram
- Transducer repair/rebuild '69 4-4-2
- 60 degree spark plug boot
- 1947 series 66 front end questions
- Roller rocker advice
- chrome plating wheels
- E85 and Fuel Sending Units
- W-30 Harmonic balancer
- brakes
- general questions
- Motor mounts 69-72 a body
- 68 442 electrical rewiring
- Another Special Part Replated By Sparky's
- Body mount color
- Help with 10 bolt rear gear ratio ?
- 67 442 Drip Rail Mldg.
- 1965 olds cutlass gas pedal
- 12 bolt type O or 10 bolt Oldsmobile rear end
- 68 442 pulleys
- Bolt on exhaust options | Dougs headers
- Interpret Casting "Clock" Symbols
- Steering column question
- Torque wrench selection, calibration, recommendations
- Looking for advice.
- 72 Cutlass Radiator Replacement
- Removing AC
- 67 C/S 330 eng, harmonic balancer
- Mirror ID
- Cowl Tag Decoder
- Engine temp fluctuating
- How to Bolt hood latch on
- Build sheet question..
- '68 442 400 c.i. Engine Bay Paint Types
- Help with W-25 Hood lock bracket
- Rear axle sticker
- Help with transmission identification
- Intake question
- 1972 Convertible - Lube Top?
- 1964 F85 clutch fork spring.
- 58 horn fittings
- 1972 Gas Tank Vapor Lines
- vac hose routing
- Wiper Transmission Hardware Questions
- Real 442?
- 1966 O.A.I. bumper bezels
- What is this thing
- Some help and advice on a couple of things
- 66 seat belt retractor disassembly
- Bellhousing date code
- correct 72 POA Valve
- 1967 442 Hose Clamps
- Tachometer
- 455 oil pan gasket replacement.
- Build dates
- '70 power bucket seat track knowledge needed
- Windshield Wiper
- Pressure gauge video
- Can I assume that if I have a 400 E code block
- 1964 F85 Z bar bushing
