Electric fuel pump fuel tank
Old Apr 17, 2020 | 08:25 PM
rfpowerdude's Avatar
Is there an aftermarket source for a fuel tank that is already setup for an in-tank pump?
I am thinking of going that route with the '70 Cutlass S...
Old Apr 17, 2020 | 08:41 PM
Qwik71442's Avatar
Full-time Taxpayer
https://classicoldsmobile.com/forums...l-pump-133598/
https://www.ebay.com/itm/Aeromotive-...-/132949814486
https://www.ebay.com/itm/70-72-Olds-...-/233493306416
these two above are the best I’ve experienced you can’t really go wrong with either. I believe the aeromotive gen 2 is a lil better in my opinion.
Old Apr 17, 2020 | 09:00 PM
70cutty's Avatar
Beer Connoisseur
I bought a Aeromotive Stealth II tank with in-tank 340lph pump for my 70. I like the Stealth II tanks much better than Tanks Inc. (that's in my Chevelle), and it's few $$ cheaper.
-6AN supply and return, came pre assembled and ready to drop in.
Old Apr 17, 2020 | 09:17 PM
Looks like the Tanks Inc. new style baffled EFI tank is the way to go!
Missed the recent tank thread so thanks for the fast heads up.
Old Apr 18, 2020 | 07:00 AM
70cutty's Avatar
Beer Connoisseur
JMO but I think stealth II is the way to go. With tanks inc tank (new design, notched corners) on my chevelle I still get fuel starvation when its below half a tank. Especially on take off, by the time I grab 2nd it stumbles.
There is more info on Chevelle and pro touring forums regarding tanks.
Old Apr 18, 2020 | 09:50 AM
cdrod's Avatar
Rodney
5th Gen Camaro Fuel Pump
I went with a RestoMod tank from Rick's Tanks which uses a late model fuel pump from a 5th gen LS3 Camaro (2010-2015). The Rick's tank does not have internal baffles, but the Camaro pump module has a siphon jet that pumps fuel into a "bucket" at the bottom of the pump body to prevent starvation. The operating pressure of the 5th gen Camaro pump is too high for most aftermarket EFI systems; the solution is to replace the 5th gen bypass "poppet" valve with one from from a 4th gen Camaro pump to reduce the pressure to 58psi. I bought a kit from a company called VaporWorx which included the 4th gen bypass valve and an electrical connector to power the pump and really clear instructions. VaporWorx told me the LS3 Camaro pump can support up to 400 HP. Another nice benefit of this set-up is the internal bypass valve in the fuel pump module will allow you use a single fuel supply line without the need for a return line (a "dead-head" system). This makes it much easier to retrofit EFI using the original factory fuel line. Here's some pics:
Old Apr 18, 2020 | 10:29 AM
dc2x4drvr's Avatar
Cdrod, thanks for advice on the 4th gen poppet, I bought the same setup after hearing from a few Olds guys.
Old Apr 18, 2020 | 01:30 PM
70cutty's Avatar
Beer Connoisseur
I tried going that route, I was planning on running PWM module from VaporWorx with my LS swap, however Rick's is completely sold out of Restomod tanks and no idea if they will bring them back. They were not selling that well, according to Rick's.
I've spent a lot of time on the phone with Rick's, Aeromotive, Tanks Inc. and Carl from VaporWorx, and many hours researching the net before I decided on Aeromotive Stealth II.
Tanks Inc baffling is not really good enough for any kind of "spirited" driving, especially if the level drops below half a tank, they will tell you that. Their 2nd design with baffling is improvement, but still not ideal.
Aeromotive Stealth II system seems like a much better design vs anything else available, unless you have $2k to burn on a custom tank.
The foam and bladder design will keep the pump submerged in fuel even when level is low.
Also at $578 (340 pump) it's cheaper vs competition.
stampsicle's Avatar
I added the Holley OE style EFI fuel pump listed below to my existing fuel tank. Works perfect.
https://www.holley.com/products/fuel...s/parts/12-303
Old Apr 18, 2020 | 03:57 PM
The Aeromotive Stealth II looks really nice and it's all put together when delivered.
Gives me options and seems better than the Tanks Inc. version...
Old Apr 19, 2020 | 04:45 AM
cdrod's Avatar
Rodney
70Cutty:
I did as you, and called RIck and Carl to get advice for my fuel system. I really wanted to use the PWM capability of the FiTech EFI to minimize fuel heat-up but was told the Aeromotive pumps are not compatible with PWM. For those that may not know, the FiTech systems can be programmed to reduce the fuel pump speed at idle; this reduces the pump noise and unnecessary fuel recirculation which heats up the fuel.
Stampcile:
The Holley pump you linked to looks like a really easy conversion, but the pump is not PWM capable which means it's running full-speed, all the time. How loud is the pump?
Rodney
Old Apr 19, 2020 | 06:17 AM
stampsicle's Avatar
70Cutty:
Stampcile:
Rodney
It’s quiet. And like you said, easy. The car came with Summit brand in-line fuel pump and it was louder than the exhaust.
Old Apr 21, 2020 | 05:05 PM
olds_freak's Avatar
I just put the Tanks Inc tank in my one of my cars last weekend. If you take your time, it all went together without issue.
jwr7042
Feb 3, 2018 11:20 AM
72delta88
Mar 14, 2017 04:35 PM
OldsCutlass70
May 4, 2013 07:13 PM
crjeeper
Apr 19, 2011 06:34 PM
Charlie_brown
Apr 6, 2010 11:41 AM
