72 350 Supreme Breather Question
Old Mar 26, 2020 | 05:38 PM
'72CutSup's Avatar
I'm looking at removing the valve filter inlet tube to the air breather on my Cutlass but the only way I can see to remove it is to destroy it. Am I missing a trick here? It's obviously 48 years old and hardened. I don't know if the replacements are pliable enough to get back in to the breather. The only reason I'm wanting to remove it is so I can repaint the breather. Pictures below:
'72 Supreme 350 breather
Valve cover filter connection tube
Old Mar 26, 2020 | 05:48 PM
Yellowstatue's Avatar
The rubber thingy is supposed to just push through. Being hard as a rock might crack it. Try some heat on it to see if it will soften.
Old Mar 27, 2020 | 04:02 AM
Those are available thru the aftermarket. If it’s hard and brittle enough to make removal difficult, I wouldn’t try to reinstall it.
Old Mar 27, 2020 | 01:32 PM
'72CutSup's Avatar
Thanks for the feedback guys. I assumed these were very soft and pliable when new but wasn't sure. I'll order aftermarket and replace.
Harmon
Nov 8, 2017 03:59 PM
JOHNNYOLDS442
Oct 8, 2015 03:58 PM
JOHNNYOLDS442
Oct 3, 2015 06:46 AM
dewcrazzy
Aug 31, 2013 07:11 PM
RetroRanger
Aug 26, 2011 06:55 AM
