Heater switch knob
Yes. If you look behind the **** you will see the shaft on all of those controls is actually a flat bar, so the key presses against the wide, flat surface and not against the thin edge.
I see the hole but is it a diff size?
” Lol, that’s what she said”
IQUOTE=Fun71;1261405]Yes. If you look behind the **** you will see the shaft on all of those controls is actually a flat bar, so the key presses against the wide, flat surface and not against the thin edge.[/QUOTE]
Ha ha ha, she said that too!!!
[/QUOTE]
