Pressure gauge video
Old Dec 26, 2019 | 12:47 AM
dragline's Avatar
I came across this video about liquid filled fuel pressure gauges which may help some members troubleshooting.
Old Dec 26, 2019 | 03:20 PM
70W-32's Avatar
Dont install liquid filled gages under the hood
Old Dec 28, 2019 | 05:23 PM
Schurkey's Avatar
Three minutes and fourteen seconds. The guy must get paid by the time he wastes. But that's common with Youtube videos, where they drone on and on and on about...nothing important or relevant. And then, instead of imparting useful info, he sends you to a Corporate Press Release, as if they were the ones who have The Only True Solution to the problem. The problem is not the gauge, per se. The problem is that folks who sell liquid-filled gauges don't bother to tell you how to use 'em because it's a hassle, and some folks won't buy them.
Here's my take. Get out your stop-watch. Let's see how long I need.
Liquid filled gauges were developed for high-vibration use. The damping fluid expands and contracts more than the gauge housing from temperature swings. This creates pressure differences inside the gauge that interferes with the mechanism. The gauge will have a rubber plug in it. MOUNT THE GAUGE SO THE RUBBER PLUG IS STRAIGHT "UP"!
Any time you want to take a pressure reading, remove the plug. You don't have to take it all the way out, but you need to "burp" the plug to equalize atmospheric pressure with the pressure inside the gauge. The next time you take a pressure reading, burp the plug again. It's a total pain in the ***, but absolutely required any time there's temperature changes where the gauge is mounted.
If you're really careful, you can poke a small hole in the rubber plug with a needle. Then the plug is "vented". In extreme vibration environments, some damping fluid can leak out; or some outside contamination can get in, but then you shouldn't need to "burp" the plug every time you want a reading.
Annnnnnd...STOP.
How long did I need?
72GoldOlds350
Apr 12, 2019 06:00 PM
57droptop
Aug 27, 2018 06:20 PM
Eightbanger
Jul 26, 2016 12:26 PM
sammieolds
Nov 11, 2015 09:59 AM
DAN76
Jul 29, 2009 02:36 PM
