PDA
View Full Version : General Questions
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21
  1. Please Help with Data Tag Decode
  2. Heater Core replacement (early 1980 Holiday coupe)
  3. 67 Cutlass factory steering ratio
  4. 1964 B body floor brackets/seat support brackets
  5. Thorntons SSI, Super Stock Ones Wheels
  6. 67 cutlass door opening measurements
  7. 68-69 Cutlass convertible trunk
  8. 1969 Delta 88 Cowl Tag decode
  9. Valve guide seals/head gaskets Toro 425 B heads
  10. Turn signal switch with tilt wheel for 1967 Cutlass
  11. 66 f85 frame
  12. Trim piece removal
  13. How to measure amount milled off head?
  14. Convertible top button 67 442 convertible
  15. Help id starter housing?
  16. Electrical connector
  17. Oldsmobile police alternator 1100671
  18. Inner Fender Well Date Code Decoding?
  19. Service replacement carburetor or original
  20. Window motor electrical connector
  21. 1964 442 Alternator
  22. 79 cutlass steering bump stop
  23. Radiator 77 Cutlass
  24. Oil priming
  25. Water Pump pulleys - need help on size.
  26. 67 442 Wiper motor removal
  27. 1965 Dynamic 88 Cowl Tag decode
  28. Tr 88
  29. Intake manifold
  30. Radiator transmission codes for 1971 w30 automatic no A/c
  31. Heater Core Access
  32. 1969 Cutlass Convertible Top Hydraulic Fitting Tightness
  33. Interior rabbit hole- seat covers for the Dynamic 88
  34. TSP fuel pump question 350 rocket
  35. interior arm rest bases 1964 Dynamic vs Cutlass F85
  36. Carburetor Restoration Service
  37. 4 way power seat chassis diagnostic
  38. Anyone have factory literature for ‘77 Delta 88 pace car?
  39. Quadrajet Rebuild Question- 1969 Hurst
  40. 455 Windage Tray needed?
  41. 1970 Cutlass Belt Squeal
  42. Power steering bracket
  43. O type axle bearing seal replacement
  44. Heater Control Valve
  45. factory sending unit with aftermarket gauges
  46. 1970 Dash - Remove Bezels to Swap Woodgrain?
  47. Severe vibrations at 40mph and above on '59 Olds
  48. 1965 98 Deluxe Horn Cap Retainer
  49. 87 98 stalling with ac off
  50. Seeking T.S.B Rochester 4 -Jet repair.
  51. Oldsmobile 324 Pulleys
  52. 1964-65-66-67 window regulator identification
  53. 1968 Vista Cruiser Column Shifter Binding
  54. Inner Fender Wells
  55. Cooling system 70 455
  56. 1948 series 76 door rubber
  57. Alternate to PerTronix
  58. Floor shift neutral switch
  59. Retorque intake manifold bolts - Oldsmobile 307
  60. Trunk Liner 75 Hurst Olds
  61. Seat Belt Guide on 75 Cutlass (H/O)
  62. 1975 H/O 455 Air Cleaner Sticker
  63. 70s 1/4 Vacuum Lines
  64. 75 Hurst Olds - Spare Tire question
  65. Transmission tag question
  66. Oldsmobile 307 replacement heater control valve
  67. Time for a carb rebuild?
  68. Collapsed/damaged steering shaft?
  69. Bluetooth 2 knob radio
  70. 67 442 Factory Tach?
  71. Heater/AC Unit Hissing
  72. 1962 crossmember
  73. 1968 Cutlass Fuel Guage needle range calibration?
  74. 66 F85 4 speed non-console
  75. Water Pump Tower Hose Clamp
  76. 1970 W-31: why no metering rods?
  77. Help with finding a part, 1963 Olds starfire carburetor
  78. Power steering pump getting weak?
  79. air cleaner ID
  80. Steering column delema.
  81. 75 Hurst Under Hood Decals
  82. 70-442
  83. 1989 delta 88 royale issue
  84. FenderEmblem Hole Locations
  85. Lares power steering pump fitting
  86. Gas tank venting
  87. ‘69 Convertible Frame Sagging
  88. '73 Custom Cruiser central locking motor(?)/door dismantle
  89. water pump / 2 groove pulley combinations
  90. 1990 Oldsmobile Delta 88 broken wire from alternator
  91. Brackets? Mounts? What are these...
  92. HELP 1963 Olds 88 suspension
  93. '73 Custom Cruiser coolant system questions
  94. Another Data Plate Decode Question
  95. 1970 Cruise Control Bellows
  96. Seat belt identification
  97. Help w/ ID-ing bumper - 1939?
  98. Headlight Adjustment
  99. 455 Engine questions
  100. Converting steering column from auto to manual
  101. Screws and clips for wiring harnesses
  102. Ring gap
  103. Distributor COLOR?
  104. Rear speaker wiring route? '67 Toronado (88, 98)
  105. Convertible window / door seal question
  106. Can someone identify this part for me (1980s 307)
  107. Question about 1986 Cutlass supreme 4 door front turn signal
  108. Radiator Seals
  109. Need to have keys code cut & stamped - Suggestions ?
  110. Locksmith question - Lock Cylinder Recoding
  111. Part number reference
  112. Harrison Air Conditioning Sticker
  113. A/c hoses 1973 cutlass supreme
  114. Wiper Blades
  115. HVAC vacuum lines
  116. Speed Hut GPS Speedometer
  117. 72 Cutlass Convertible build sheet decode
  118. Neg battery lead termination location.
  119. What is this noise?
  120. Seen in a French car magazine
  121. Delco Nos R71 battery value
  122. 8.2 rear axel outer dust seal
  123. Trunk Release Cable Clip Location
  124. Camshaft and lifters
  125. Motor Code Decal
  126. Radiator overflow tube clip
  127. Bolt help needed.
  128. Oil Filter Adapter Types
  129. 1968 A body instrument panel repair
  130. 1957 Olds Hoods: Differences?
  131. 1971 Cutlass gas cap help
  132. New gas tank install
  133. 1965 olds 98 master cylinder
  134. 1961 Sky Rocket in a 1964 Dynamic?
  135. 66-442 poor front bumper fit.
  136. Twin-snorkel air-cleaner base
  137. ID this Olds cable bracket?!!
  138. Engine ID help
  139. 330/350 Flexplate
  140. hood latch
  141. Charcoal Canister Delete
  142. Gas tank and strap rubber mats
  143. Pulley help needed
  144. 1964 394 won't start
  145. Power Steering Pump Selection - Rack and Pinion
  146. 1971 Cutlass "S" hardtop coupe Arlington production
  147. 1971 Arlington 442 production
  148. 1971 Arlington production
  149. Quadrajet carb question.
  150. I think no fuel - broken fuel pump?
  151. The Idle Load Compensator - How Is It Supposed To Work?
  152. Oldsmobile cutlass salon 79 subframe
  153. Cruise control question
  154. Ethanol in fuel
  155. 455 Thermostat
  156. 94 cutlass convertable 3.4L fuel pump
  157. Correct sparkplugs for HEI vs non-HEI
  158. Smokin' start to the week
  159. Coolant leak in passenger footwell & vent issue ('72 Cutlass)
  160. 1966 Olds 442 front bumper brackets
  161. 1970 442 Convertible Blower Motor
  162. Need heater control diagram - '57 Olds Super 88 J2 car
  163. Fuel Filter Housing
  164. Trunk locks 67 CS
  165. 1970 A/C Heater control vacuum canister testing
  166. Cruise Control
  167. Mirror mounting template
  168. 1980 Delta 88 owners manual
  169. 394 timing chain and marks
  170. Vanity mirror inserts
  171. Need correct names for vinyl top and interior colors - 1970 Cutlass
  172. replacement wiper rubber
  173. Convertible Guide Pin
  174. Tech advice on 63 Olds 88 Valve cover PCV grommet
  175. Masticated rubber versus neoprene for splash shields
  176. Moog or TRW Coil Spring Number for 66 442 with AC
  177. Cruise Control
  178. Vapor lock problems, 71 CUtlass 350
  179. 66 442 Picture Needed for an Installed Taped Plastc T to the Wiring Harness
  180. Tach rebuild?
  181. Dual Gate hard to shift
  182. hood rear weatherstripping
  183. Driver door glass
  184. Timing tab and Harmonic Balancer
  185. Factory Chrome Valve Covers
  186. 1984 Delta 88 Coupe door hinge
  187. 66 toronado exhaust manifold
  188. Rubber radiator isolators
  189. 62 f85
  190. Thermostats
  191. New Coil Spring Compressor…?
  192. 69 Cutlass S convertible steering wheel
  193. '70-'72 Kick Panel Restoration
  194. 3.8 coolant line
  195. How to remove A-pillar stainless trim??
  196. 1993 Olds Ciera 3.3L + poor heat
  197. What did I buy?
  198. Is this the right label?
  199. 1970 Vista A/C Air Flow Problem
  200. Getting pulley off power steering pump
  201. No data plate
  202. Recommended fluids
  203. Camshaft dowel pin location
  204. Where to purchase pistons
  205. Specifics of W-31 JO transmssion
  206. Pondering fixing no show in dash right turn signal in 96 LSS
  207. New to me 1970 f85
  208. Can you change steering wheels from a standard steering column to tilt wheel column
  209. What year was this steering wheel used in full sized Oldsmobiles.
  210. Hood Problems on 1968 Oldsmobile 442
  211. Aluminum Radiator Repair
  212. Bumper bolts
  213. 68 delta 88 fuel tank issue
  214. Help with 68 lower radiator hose
  215. Factory screw ups
  216. 371 Flex Plate
  217. What is this part?
  218. Decoding a 1972 Olds Build Sheet Date
  219. 67 442 Quadrajet float level 7027157
  220. Shifting Delays / '69 H/O OH Transmission
  221. '70 Cutlass S 350 Fan Shroud Install
  222. Valve Spring Pressure, does reduce after break-in?
  223. Anyone put a/c in their ‘67 Cutlass/442?
  224. .921 vs. .842... Are Cam Cores the same?
  225. Funky fuel line
  226. Is this going to be a problem?
  227. Start up checklist.
  228. Bodyside trim removal on 67 442
  229. 69 hurst mirrors???
  230. 1972 Cutlass S Crank but no start
  231. Can anyone please translate my plate?
  232. 66 F85. Rochester 2bbl. Hard to start
  233. Starter - 1971 Cutlass Supreme
  234. 67 442- AC dash control rebuild
  235. Shock Bushings
  236. Exhaust pipes
  237. 1969 Speedometer sticker
  238. Block numbers help
  239. Heater Hose/ Modulator Line Arrangement
  240. Delco radio connector terminals?
  241. Looking for Stainless trim restoration shop - SE WI
  242. Overheating When Parked
  243. 57 windshield washer hose diagram
  244. Heat on and off
  245. 65 Vista Cruiser fuel tank vent
  246. Exaust manifolds wz
  247. oil drain back in my 324
  248. Olds Super 88 1960MY
  249. 1965 Cutlass F85 grill assembly??
  250. What’s this part called? Steering column issue
