Retorque intake manifold bolts - Oldsmobile 307
Old Aug 2, 2024 | 08:43 AM
1987CadillacBrougham's Avatar
Hello - I recently replaced my intake manifold gasket on my car with an Oldsmobile 307 engine. As I understand you are supposed to retorque them after the first couple heat cycles.
As it turns out since I had a lot of work to do on the car I ended retorqued the bolts about 5 times (every day I went out to work on the car I'd start by torquing the intake manifold). The first two times I did this I did end up tightening the bolts before the wrench clicked. After that the wrench more or less instantly clicked.
Is that good enough? I figured from the factory or if I took it to a mechanic they would not retorque it.
Admittedly I am just trying to avoid removing a bunch of stuff off the engine so I can get at the bolts again.
The engine runs beautifully, I definitely fixed a vacuum leak in the manifold (or maybe one of the lines I replaced was bad) because it runs, sounds, and drives so much better now.
Old Aug 2, 2024 | 09:48 AM
Best practice is to retorque the gasket. I'm not sure if it's mentioned in the Factory Service Manual though.
Old Aug 2, 2024 | 10:04 AM
69HO43's Avatar
Should be good enough if you're not getting any more movement out of the bolts. 3rd time should have done it at most.
Old Aug 2, 2024 | 10:07 AM
Sugar Bear's Avatar
IMO you're good to go. I'd resist tightening them anymore as it unnecessarily disturbs the seal...it may do more harm than good.
Old Aug 2, 2024 | 10:09 AM
If you see no oil seepage on any bolt leave them alone.
Chuxter
Nov 3, 2023 05:41 PM
oldguy442
Sep 10, 2021 01:41 PM
Rvsmith5
Jul 26, 2018 05:44 PM
yankees
Aug 9, 2012 07:01 AM
blue72regency
Nov 10, 2007 05:02 PM
