Intake Manifold Question
Old Sep 10, 2021 | 11:16 AM
oldguy442's Avatar
As part of my 455 build I am installing an original 1970 W455 aluminum intake. I am having trouble locating the correct intake bolts. The manifold requires 4 short and 8 long bolts. All of the kits I have researched appear to contain just the opposite. Has anyone else had this problem and if so where did you locate the correct bolts?
Old Sep 10, 2021 | 11:36 AM
442Harv's Avatar
Did you check Elderbrock? I bought mine from them, but that was years ago.
VC455's Avatar
Barely Registered
I measured what I needed, went to a bolt specialist company, and bought the correct length bolts and hardened washers. Doing that will not get you factory-correct fasteners, but for my application it was the easiest and least expensive way to get the look I wanted
Otherwise, Fusick Automnotive has a bolt kit that is much closer to factory appearance (IBK647 at $40).
Old Sep 10, 2021 | 01:41 PM
oldguy442's Avatar
Thanks guys. I think I may have found them at Oldsrocketparts com. I will follow up on this thread when I receive them . They were in stock.
Rvsmith5
Jul 26, 2018 05:44 PM
ReallyWildStuff
Jan 8, 2018 05:19 AM
1969cutlass4d
Apr 20, 2015 10:54 AM
foo
Dec 29, 2013 04:33 AM
projectheaven
Jul 15, 2011 12:00 PM
