intake bolts
Old Nov 2, 2023 | 02:31 PM
Chuxter's Avatar
1970 Cutlass Supreme
intake bolts
I pulled my intake to clean and put new gaskets on and I was wondering if I can replace the bolts and hardened washers ? The bolts appear to be grade 5. Where can i find the washers? What are your thoughts?
Old Nov 2, 2023 | 04:04 PM
You should be able to get hardware locally. I suppose you could buy an ARP kit, but you don't need special hardware for the intake manifold. Here's another thread
https://classicoldsmobile.com/forums...e-specs-65357/
Old Nov 2, 2023 | 04:21 PM
I replaced mine when I changed out the intake manifold gasket. I can't recall if they were Grade 5 or Grade 8. None-the-less, my local Ace Hardware had the exact fit bolts & washers of the same Grade.
Old Nov 2, 2023 | 05:43 PM
Why not clean up the stock bolts?
Old Nov 2, 2023 | 08:43 PM
Grade 5 bolts are fine, but that grade washers are thin and soft and can distort. I bought Grade 8 washers at the local hardware store.
Old Nov 3, 2023 | 05:41 PM
pavemobile's Avatar
pavemobile
I used structural washers from Fastenal, I had a sample I took with me though
madmax442.com
Feb 27, 2023 07:41 AM
1969cutlass4d
Apr 20, 2015 10:54 AM
Tim305
May 20, 2014 05:51 PM
seok
Mar 6, 2011 08:24 PM
ziff396
Feb 16, 2009 08:15 PM
