Trunk Release Cable Clip Location
Old Apr 28, 2024 | 12:39 PM
72Vert442's Avatar
I have looked through the assembly manual several times and cant locate where is shows how many clips are used to hold the trunk release cable to the hinge. Is it two clips or one? Clip location is on the trunk hinge?
Old Apr 28, 2024 | 01:23 PM
I'm going to hedge a bet you're referring to a 1972 Oldsmobile 4-4-2? It's always to your benefit to indicate the model & year, we possess no supernatural powers.
Old Apr 28, 2024 | 01:43 PM
72Vert442's Avatar
Yes,
Old Apr 28, 2024 | 02:09 PM
https://classicoldsmobile.com/forums...outing-126901/
https://classicoldsmobile.com/forums...utlass-124933/
Old Apr 28, 2024 | 02:43 PM
72Vert442's Avatar
Checked both of these threads but dont see where is talks about or shows the cable clips in the trunk. Looking for how many clips are used and where they are mounted on the hinge.
Old Apr 28, 2024 | 03:02 PM
Don't know. Good Luck.
Old Jul 7, 2024 | 09:27 AM
Toms cutlass's Avatar
I asked the same question with same results:
https://classicoldsmobile.com/forums...cation-173140/
I studied images and looked at ads selling the entire trunk release kit. There are 2 clips both attached on the far right edge of the right side hinge of the trunk. Good luck!
Toms cutlass
Jul 7, 2023 11:52 AM
rkk69olds
Dec 28, 2022 03:55 AM
Rickman57
Dec 1, 2021 07:38 AM
kencpless@gmail.com
May 29, 2020 04:51 PM
kencpless@gmail.com
May 24, 2020 08:45 AM
