Twin-snorkel air-cleaner base
Old Apr 9, 2024 | 02:33 AM
Aus78Formula's Avatar
Anyone recognise this air cleaner base? Possibly a later 442 Olds? I can't find the exact 1.5 snorkel arrangement along with having HEI. Thanks
by https://www.flickr.com/photos/196419001@N03/, on Flickr
Old Apr 10, 2024 | 02:39 PM
oldoldss's Avatar
Does it look like this: 1970 1971 1972 Dual Snorkel Air Cleaner Olds Cutlass 442 - ClassicOldsmobile.com
Old Apr 10, 2024 | 05:18 PM
Excellent, thanks!
Yes, that's the style it reminded me of but this is a later version. It has clearanced rear for HEI distributor, the short snorkel has more of a lip, the longer snorkel has no lip and possibly took a ducting hose??
It's not mine but one for sale, the guy didn't know what it was and I went to tell him and then realised it was slightly different to what I thought. The poor pics are from the ad. I've updated my first post, for some reason it only showed one pic and was tiny. I'm not sure why it is doubling the images, did that in my other posts also.
Old Apr 10, 2024 | 07:05 PM
The long snorkel also has provision for a plastic elbow for the corrugated inlet duct hose. Mid-70s something. The lid looks Chevy.
Old Apr 10, 2024 | 07:10 PM
It's kind of the mirror image of this Dodge truck unit.
Old Apr 11, 2024 | 04:13 AM
69HO43's Avatar
Olds used that same lid up through mid-86, and was chromed on an 80s H/O or 85/early 86 442 (I guess they borrowed that from the Corvettes) but that is NOT an Olds air cleaner (they went to a flatter top air cleaner lid mid-86 with no "bead"). Also, the main inlet would be on the left side and the mini-snorkel would be 180 degrees out facing the HVAC Evaporator housing if it were an Olds VIN 9 style air cleaner.
Resembles something that Chevy or Pontiac may have tried. Likely off a SBC of some sort is my guess. I don't keep up with their junk at all.
Old Apr 11, 2024 | 04:32 AM
Thanks, good info.
Old Apr 11, 2024 | 02:51 PM
therobski's Avatar
So once upon a time a made a dual snorkel air cleaner out of two 425 Starfire air cleaners and after all the work make it look like the real deal never a cured to me that the lid height was higher than the 64 F-85 . Once I put my master piece on the 64- no hood clearance!
Old Apr 24, 2024 | 08:11 PM
joes_olds's Avatar
The flange on the end of the short side doesn't resemble an Olds short snorkel based on the 70-72 link or the 74/75(?) version. Also the underside of the short snorkel looks different than any I have seen.
Closest I've seen is this one.
https://classicoldsmobile.com/forums...leaner-161305/
My guess would be homemade.
Cavet, I'm no Joe Padavano, respectfully.
pnagy23
May 9, 2022 03:12 AM
tdhill01
Jan 27, 2016 11:41 AM
pureplaya442
Hurst/Olds
Dec 22, 2015 09:53 AM
Cincinnati Rick
Nov 29, 2014 01:53 PM
grt05
Nov 3, 2009 02:30 PM
