Steering column delema.
Old Jun 23, 2024 | 06:46 PM
forddom's Avatar
Hey guys, so I have two columns here the one on the right is a 68 442 auto on floor. The right is a 72 tilt but the linkage bracket is much different. Could this be for a 4 spd? Also the 69 column has a spring at.the bracket the 72 does not. Is it missing? Are the brackets welded or can the be swapped?
Old Jun 23, 2024 | 07:03 PM
70Post's Avatar
Tilt columns don't use the large spring at the bottom of the column.
The "linkage bracket"/arm on the column on the Left (first pic) is correct for BOTH auto and 4 speed.
Old Jun 23, 2024 | 07:51 PM
forddom's Avatar
Thanks 70 post,So I guess I will need The linkage for the tilt column (left one.) As the linkage from the column on right will be to small I'm guessing.
Old Jun 23, 2024 | 09:54 PM
VI Cutty's Avatar
Did the bracket connect to anything on the 4 speed or was it fixed in place?
Old Jun 24, 2024 | 04:15 AM
Your "1972" tilt column looks like a 73-77 column. All 1969-newer GMs had a backdrive linkage from the trans to the column. This was to lock the shifter with the key, per federal law. Yes, even floor shift cars had this.
Old Jun 24, 2024 | 10:08 AM
70Post's Avatar
Joe answered the question.....yes, the 4 spd column uses the "back drive" parts like an auto column does.....again, the columns are THE SAME THING. There is no separate "4 speed" column....at least for the years we are discussing.
Old Jun 25, 2024 | 05:25 AM
oddball's Avatar
What are you seeing on the tilt column, for my education? That looks like a '72 to me.
Old Jun 25, 2024 | 05:58 AM
The 69-72 and 73-77 columns are nearly identical except for that lever for the backdrive linkage. The 73-77 columns use the straight lever, the earlier ones use the curved lever.
brandon reynolds
Feb 27, 2023 12:33 PM
fiebs442
Suspension & Handling
Aug 8, 2021 02:06 PM
jerryl
Apr 3, 2019 11:14 AM
starfire
Aug 4, 2013 05:39 AM
67442nut
Mar 7, 2013 07:02 PM
