Oldsmobile cutlass salon 79 subframe
Old Mar 22, 2024 | 07:32 AM
79 olds's Avatar
Hi all.
i have oldsmobile 79 cutlass salon.
how can i identify the subframe style for checking the alignment?
Old Mar 22, 2024 | 07:43 AM
rocketraider's Avatar
Oldsdruid
Your Salon is an A body and has a full perimeter frame. None of those designations apply.
1970s GM platforms:
F is Firebird and Camaro.
H is Chevrolet Monza, Olds Starfire, Buick Skyhawk and Pontiac Sunbird.
K is Cadillac Seville.
X is Chevrolet Nova, Olds Omega, Buick Skylark and Pontiac Ventura.
Old Mar 22, 2024 | 08:30 AM
79 olds's Avatar
oldsmobile 79 cutlass salon full perimeter frame
It is possible that one of these frames match several bodies?​​​​​​​
Old Mar 22, 2024 | 02:36 PM
Oldsdruid
Put the Fisher Body Manual away. The section you're fixated on is for unit-body cars with front and rear subframes and has nothing to do with your Salon, which is separate body-on-frame construction.
Look in the Chassis Service Manual Section 2A for diagrams and dimensions for your Salon.
Here's the series designation from the CSM. Notice Oldsmobile didn't produce F or K platform cars and Salon is considered a body-on-frame A platform car.
Old Mar 22, 2024 | 03:03 PM
79 olds's Avatar
Oldsmobile cutlass salon 79 frame
Thanks!
i found the dimensions in the 1979 oldsmobile services manual. but still there is missing vertical dimensions
It was said that the frame of "Cutlass, 88, 98 and Tornado are basically the same", so could it be the horizontal dimensions are the same?
or i missing something?
Old Mar 23, 2024 | 07:48 AM
No, no, and no. The Cutlass is an A-body. It has a 108" wheelbase on a full frame. The other Olds full frame cars have different wheelbase, width, and length. The frames do not interchange and the dimensions are completely different. The Chassis Service Manual diagram is only intended to provide the info for checking wracking, which is the most common distortion in a collision. It is not intended to provide full frame dimensions. You would need a frame chart book for that.
https://www.ebay.com/itm/192889007335
Old Mar 23, 2024 | 02:35 PM
79 olds's Avatar
Thanks!!
F-85 4-4-2
May 17, 2023 08:15 AM
MagicMan
Apr 18, 2021 09:15 AM
79 olds
May 2, 2020 09:59 AM
Mr.Cutty
Jul 30, 2014 04:07 AM
