3.8 coolant line
Old Dec 24, 2023 | 06:34 PM
deaddds's Avatar
3.8 coolant line
There is a metal coolant line that circulates for the throttle body. Its tucked just underneath the TB. Its got a plate with a gasket that is held by 2 studs. I cant find it in any diagrams to be able to look up a GM part number. There is a second bent tube just above the bolted on one that has O rings and it gets pressed in that I believe also circulates coolant. I cant find the name of this tube either to hunt down replacements. They have corrosion holes in them and then leak on top of the motor. Anybody know how to ID these rascals?
Old Dec 25, 2023 | 01:23 AM
Year and model might help
Old Dec 25, 2023 | 04:52 AM
The 3.8l Series II used in FWD 88s and 98s (early to mid 90s) used a belt tensioner that was a coolant prlenum. Two hose barbs fitted onto the belt tensioner which led to the heater core. These hose barbs would often fail since the OE barbs were plastic. You can get aftermarket metal replacement fittings.
GM also used coolant in throttle bodies and alternators during those years. I recall reading on a Cadillac forum that someone had to tap the throttle body on their car and install an NPT hose barb in it to make a repair.
Post a pic and let us know what car you're working on.
Old Dec 25, 2023 | 05:21 AM
deaddds's Avatar
1988 88.
Old Dec 25, 2023 | 06:07 AM
66_Jetstar's Avatar
I remember bypassing the heated throttle bodies in search of a few HP. Although there were a few models where that also acted as the bypass, so it was not a good idea.
Old Dec 26, 2023 | 06:05 PM
deaddds's Avatar
That was the 1988 88 with the photo.
Old Dec 26, 2023 | 06:55 PM
BillK's Avatar
The part numbers for a Toronado are 24500035 and 25533986
Old Dec 27, 2023 | 03:58 AM
C'mon the OP already mentioned it was a 1988 88.
Old Dec 27, 2023 | 06:16 AM
BillK's Avatar
My fault . . . thought the extra 88 was a double My apologies
Old Dec 28, 2023 | 06:20 AM
deaddds's Avatar
Thank you Bill. I’ll do some digging and see if I can hunt them down. Much appreciated.
TheBagle
Feb 28, 2023 10:10 AM
jmac103
Aug 25, 2022 09:31 AM
RustyOlds
Sep 23, 2016 10:04 PM
bob p
Brakes/Hydraulic Systems
May 7, 2015 11:11 AM
t65belair
Alero
Jun 6, 2007 11:54 PM
