455 Windage Tray needed?
Old Aug 15, 2024 | 04:14 PM
rudeke's Avatar
Question 455 Windage Tray needed?
Building a 455 with .030 over pistons, mild cam, and headers. Shop strongly recommending a windage tray. It appears stock engines did not have them? Any thoughts?
Old Aug 15, 2024 | 04:17 PM
Originally Posted by rudeke
Building a 455 with .30 over pistons
Any thoughts?
Drop the piston size down to .030 over to maintain cylinder wall thickness.
Old Aug 15, 2024 | 04:55 PM
v8al's Avatar
Registered Olds Owner
In general I'd say they aren't required however there really isn't any harm in installing one except the hassle. It will help with higher RPM oil control.
Keep in mind though all full length Oldsmobile windage trays are custom and more than likely will require custom grinding/fitting to work for your application.
You will need to:
  • Purchase or find the correct bolts or studs/spacers/nuts to install the tray.
  • Buy a kit from various suppliers but count on installing it multiple times to get the fit right.
  • Verify that your dipstick tube and dipstick will correctly clear the windage tray.
  • Ensure enough clearance between crank, rods, rod bolts and the tray.
  • Loctite the nuts securing the tray.
Onit
Aug 18, 2022 06:45 AM
MO Olds 2022
Apr 16, 2022 01:24 PM
71DP
Nov 22, 2021 09:08 PM
rpinnt
Dec 3, 2017 06:08 AM
442Dave
Aug 29, 2012 06:44 PM
