1970 Dash - Remove Bezels to Swap Woodgrain?
Old Aug 12, 2024 | 08:29 AM
WTHIRTY1's Avatar
Escape From The Ordinary
Question 1970 Dash - Remove Bezels to Swap Woodgrain?
A previous owner installed the aftermarket '70 burlwood overlay on the dash of my convertible. I prefer the original woodgrain overlay and have sourced mint woodgrain. In order to install, I need to remove the two "bezels" for the wipers and convertible top. It has been a long time since I've attempted removing the bezels from underneath (or through the gauge pod?). Anyone have a quick and straightforward approach to removing those two bezels so I can get the switches removed to swap the woodgrain?
Old Aug 12, 2024 | 12:18 PM
alain's Avatar
Hi Jim
No easy fix to your dilemma.I have no rabbit in my hat.
Alain platinum 442 4spd factory A/C
Old Aug 12, 2024 | 12:30 PM
70sgeek's Avatar
'72 Cutlass ragtop
I've not had to remove either bezel on my '72 but did have to replace the convertible top switch - was a PITA but ultimately had to work through the open gauge hole with a small mirror and I if I recall correctly, a tiny 1/4" open wrench. I recall the mounting bolts being positioned nearly right up against a dash frame bracket, so getting in between it to undo them from the back side of the dash was a gymnastic act.
I do recall there are some prior threads on the board about this process so u can also try searching them to see what others have done (or recommended) in the past.
Old Aug 12, 2024 | 02:06 PM
dc2x4drvr's Avatar
70sgeek is right, it’s a PITA to remove the bezels, I’ve used 1/4” ratchet with an extension to get the nuts off, I don’t recall the size…this is where a mirror is helpful to find the fasteners location.
Good luck..
Old Aug 13, 2024 | 07:13 PM
70Post's Avatar
the socket/wrench size is 1/4" (as 70sgeek mentioned above)....the stamped steel "speed" nuts that are used to hold the two chrome bezels on.
Old Aug 13, 2024 | 08:10 PM
Mr Shifty Sidney's Avatar
Here is a picture. Of course you will have the plug to deal with also. Good luck.
Don W
Old Aug 16, 2024 | 05:54 PM
joesw31's Avatar
Pull the gauge bezel, then pull the speedometer and fuel gauge. This will you access to the back of the dash. This is the easiest way that I have found. Hope this helps.
major tom
Feb 15, 2024 01:56 PM
jmcghee
Wheels and Tires
Sep 8, 2022 12:51 PM
Mr Shifty Sidney
Aug 31, 2020 10:01 PM
joesw31
Oct 25, 2015 11:03 AM
bigdooly
Oct 13, 2015 05:32 PM
